Home > Puma (Tdci) > immobiliser stopped working, no start |
Alien Member Since: 18 Jan 2015 Location: Bacchus Marsh Posts: 230 |
I can't help but would be interested in finding out what the fault is once you get it sorted. Cheers,
Kyle. |
30th Jan 2016 10:33pm |
Tjhappel Member Since: 08 Aug 2012 Location: Southern California Posts: 32 |
I'll let you know for sure... to say but my aftermarket cruise control has been the most reliable feature of my entire vehicle. I really love my car but it's just unreal all the issue it has. Hopefully someone on the forum can help me with this issue???
Please |
31st Jan 2016 4:52am |
Jukathy Member Since: 25 Jan 2015 Location: Berlin Posts: 170 |
Super dim carlights? Seems like a battery issue to me. How old? What about undervoltage?
31st Jan 2016 8:34am |
Wild Card 90 Member Since: 03 Dec 2014 Location: Gerlingen Posts: 1060 |
Tjhappel, your description is somewhat confusing. What do you mean by the driver door immobiliser? Do you mean the door lock actuator (a solenoid)? Would seem apparent that on the way to the rear of the car the power to the door lock actuators gets interupted. The fact that the immobiliser was setting off the alarm suggests that it senses that something had shorted. Did your indy disconnect a wire or bypass something to get things working. My guess is the problem is in the wiring (damaged insulation, something shorting to the body) and not with the solenoid. Ask your indy what he did. Hope this helps. 1998 Tdi 90 SW, 2008 Td4 90 SW, 2012 2.2 90 SW, 2" raised Trailmaster/Terrafirma Heavy Track Raids, 255 MTīs, Recaro CSīs, anorak, wellingtons |
31st Jan 2016 10:41am |
sorry for anything confusing, the power door locks stopped working and the car wouldn't turn on. Interior lights were on and very dim even though the car was closed and locked. After a ton of searching the right rear door had some wiring crumbling and overlapimg the other wires and short out the rest of the car. I have backup cameras installed and I'm not positive but I believe it's in those wires somewhere, my car is up and running now but lost the reverse camera and the rear speakers.
Thanks for getting back to me everyone, sorry for anything confusing. I really am thankful we have a site like this to turn to for help! |
3rd Feb 2016 5:30am |
AlanH Member Since: 15 Mar 2010 Location: WA Posts: 242 |
You may need this site many more times during your Defender ownership Tjhappel. But in between those frustrating probs I'm sure you'll enjoy it.....
AlanH. |
6th Feb 2016 8:18am |
Merlin Member Since: 30 Oct 2010 Location: Newmarket Posts: 981 |
I had a non starting problem, similar to you. The AS10 terminals were corroded. These were cleaned and all was well. Might not be your problem but you never know!
Merlin |
6th Feb 2016 5:43pm |
Found the issue in right rear door, wires corroded and that was causing the short. Thanks for your help guys..,
7th Feb 2016 10:26pm |
