Home > Puma (Tdci) > immobiliser stopped working, no start
Tjhappel
United States 2010 Defender 110 Puma 2.4 XS CSW Santorini Black
So I'm thinking I have a short somewhere, I parked my car locked it and walked away. 30 minutes later I went to unlock it and nothing. I also noticed at the same time all of my interior lights are on but super dim, like 10% of normal, if I actually turn the light on it'll come on at 100% percent. Battery is fully charged, I checked all fuses and battery terminals are tight so that's not it. When I go to start it the alarm just goes off and the horn won't stop. I am about 3000 miles away from anyone who knows anything about a puma..... Any help greatly appreciated. 2010 def 110.
Update: Small Indy shop found a fault with driver door immobiliser, got a new one and now the front two doors open and now the car will start but the rear doors and tailgate door stopped opening and closing, again leading me to think I habe a faulty switch somewhere or a mystery short!
Post #497256 28th Jan 2016 7:34am
Alien
Australia
I can't help but would be interested in finding out what the fault is once you get it sorted. Cheers,
Kyle.
Post #498464 30th Jan 2016 10:33pm
Tjhappel
I'll let you know for sure... Censored to say but my aftermarket cruise control has been the most reliable feature of my entire vehicle. I really love my car but it's just unreal all the issue it has. Hopefully someone on the forum can help me with this issue???
Please
Post #498486 31st Jan 2016 4:52am
Jukathy
2012 Defender 110 Puma 2.2 SW Keswick Green
Super dim carlights? Seems like a battery issue to me. How old? What about undervoltage?
Post #498506 31st Jan 2016 8:34am
Wild Card 90
England 2012 Defender 90 Puma 2.2 SW Indus Silver
Re: immobiliser stopped working, no start
Tjhappel, your description is somewhat confusing.
What do you mean by the driver door immobiliser? Do you mean the door lock actuator (a solenoid)?
Would seem apparent that on the way to the rear of the car the power to the door lock actuators gets interupted. The fact that the immobiliser was setting off the alarm suggests that it senses that something had shorted. Did your indy disconnect a wire or bypass something to get things working.
My guess is the problem is in the wiring (damaged insulation, something shorting to the body) and not with the solenoid.
Ask your indy what he did.
Hope this helps. 1998 Tdi 90 SW,
2008 Td4 90 SW,
2012 2.2 90 SW,
2" raised Trailmaster/Terrafirma
Heavy Track Raids, 255 MTīs,
Recaro CSīs, anorak, wellingtons
Post #498557 31st Jan 2016 10:41am
Tjhappel
sorry for anything confusing, the power door locks stopped working and the car wouldn't turn on. Interior lights were on and very dim even though the car was closed and locked. After a Censored ton of searching the right rear door had some wiring crumbling and overlapimg the other wires and short out the rest of the car. I have backup cameras installed and I'm not positive but I believe it's in those wires somewhere, my car is up and running now but lost the reverse camera and the rear speakers.
Thanks for getting back to me everyone, sorry for anything confusing. I really am thankful we have a site like this to turn to for help!
Post #499787 3rd Feb 2016 5:30am
AlanH
Australia
You may need this site many more times during your Defender ownership Tjhappel. But in between those frustrating probs I'm sure you'll enjoy it..... Rolling with laughter
AlanH.
Post #501136 6th Feb 2016 8:18am
Merlin
I had a non starting problem, similar to you. The AS10 terminals were corroded. These were cleaned and all was well. Might not be your problem but you never know!
Merlin
Post #501354 6th Feb 2016 5:43pm
Tjhappel
Found the issue in right rear door, wires corroded and that was causing the short. Thanks for your help guys..,
Post #501924 7th Feb 2016 10:26pm
