Home > Maintenance & Modifications > Removing the transfer stick
mcma1
What's involved with removing this? I know the gear stick is just clips. Andy
2014 Fuji 110 SW LS3
https://www.defender2.net/forum/post751233.html#751233
2014 Corris 110 SW
http://www.defender2.net/forum/topic40056.html
My old Xtech 90 build..
http://www.defender2.net/forum/topic15681.html
LS3 V8 build...
http://www.defender2.net/forum/topic49051.html
Post #498973 1st Feb 2016 9:04am
YOLO110
Australia
I believe it is very similar also with clips... Question YOLO... You Only Live Once...
Post #498984 1st Feb 2016 9:28am
K9F
No it's not. Mine came as a complete assembly and you have to change either the attaching box and the linkage as a complete assembly or just the linkage alone can be popped off and left but the box goes with the lever regardless. Tunnel cover off for access but not too difficult, maybe an hour to an hour and a half?
 If you go through life with your head in the sand....all people will see is an ar5e!!
Post #499030 1st Feb 2016 11:09am
L90Andy
United Kingdom 1997 Defender 90 300 Tdi ST Nato Green
Re: Removing the transfer stick
To just remove the stick from inside the vehicle leaving all the mech in place, just sharply pull it upwards. I did this the other week when I added leather gear levers. Easy.
Post #499052 1st Feb 2016 12:01pm
mcma1
Thank guys,
I have the adventurer ones to fit, the gear stick is the same, but the transfer knob appear to be only the knob and not the assembly, question is now, can you remove the standard knob with having to cut it? its just bonded on a assume. Andy
2014 Corris 110 SW
LS3 V8 build...
Post #499058 1st Feb 2016 12:20pm
Exactly right Thumbs Up
Post #499060 1st Feb 2016 12:21pm
mcma1
So no unscrewing anything?, just some good old brute force? Andy
2014 Corris 110 SW
LS3 V8 build...
Post #499062 1st Feb 2016 12:24pm
Yup Thumbs Up
Post #499065 1st Feb 2016 12:29pm
mcma1
Post #499087 1st Feb 2016 1:12pm
