Home > Maintenance & Modifications > Removing the transfer stick |
mcma1 Member Since: 16 Oct 2012 Location: Northern Ireland Posts: 2882 |
What's involved with removing this? I know the gear stick is just clips. Andy
2014 Fuji 110 SW LS3 https://www.defender2.net/forum/post751233.html#751233 2014 Corris 110 SW http://www.defender2.net/forum/topic40056.html My old Xtech 90 build.. http://www.defender2.net/forum/topic15681.html LS3 V8 build... http://www.defender2.net/forum/topic49051.html |
1st Feb 2016 10:04am |
YOLO110 Member Since: 14 Feb 2015 Location: Perth Oz and Stansted UK Posts: 1640 |
I believe it is very similar also with clips... YOLO... You Only Live Once...
1st Feb 2016 10:28am |
No it's not. Mine came as a complete assembly and you have to change either the attaching box and the linkage as a complete assembly or just the linkage alone can be popped off and left but the box goes with the lever regardless. Tunnel cover off for access but not too difficult, maybe an hour to an hour and a half?
If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
1st Feb 2016 12:09pm |
Thank guys,
I have the adventurer ones to fit, the gear stick is the same, but the transfer knob appear to be only the knob and not the assembly, question is now, can you remove the standard knob with having to cut it? its just bonded on a assume. Andy 2014 Fuji 110 SW LS3 https://www.defender2.net/forum/post751233.html#751233 2014 Corris 110 SW http://www.defender2.net/forum/topic40056.html My old Xtech 90 build.. http://www.defender2.net/forum/topic15681.html LS3 V8 build... http://www.defender2.net/forum/topic49051.html |
1st Feb 2016 1:20pm |
Go Beyond Member Since: 30 Jan 2012 Location: Headcorn, Kent Posts: 6677 |
Exactly right |
1st Feb 2016 1:21pm |
So no unscrewing anything?, just some good old brute force? Andy
1st Feb 2016 1:24pm |
Yup
1st Feb 2016 1:29pm |
You are quite right, Andy
1st Feb 2016 2:12pm |
