Home > Puma (Tdci) > Puma 2.4 oil leak location
muddypaws
England 2009 Defender 90 Puma 2.4 SVX Station Wagon Santorini Black
Hi
Can someone identify the arrowed pipe that is leaking engine oil please - being more familiar with petrol V8's I'm not sure what this is!!
Thanks very much
https://www.defender2.net/gallery/albums/u...engine.jpg Richard
Defender 90 SVX
Post #496202 25th Jan 2016 2:30pm
muddypaws
Hmm - picture is very small - its the big 'U' shaped pipe in the middle thats leaking at the lowest point Richard
Defender 90 SVX
Post #496203 25th Jan 2016 2:32pm
o4dn
France 2009 Defender 90 Puma 2.4 SW Alaska White
Pic is small because you linked the thumbnail image.
The full size image is here (from your gallery):
 “A Land Rover immobilized is a moral defeat for the driver and bad publicity for the vehicle, […] it's up to you to do justice to your Land Rover!” - Land Rover Driving Technique.
2009 2.4 Puma Defender 90 SW
1979 Land Rover Series 3 88"
Post #496206 25th Jan 2016 2:39pm
The "pipe" you've arrowed is the main engine wiring harness. Nothing should be leaking from it!
In time however you will find that it chafes on the brackets it's secured to, and if not spotted and repaired in time major amounts of smoke will leak from it!
Post #496207 25th Jan 2016 2:45pm
Eduardo
Did you check the vaccum pump located just below the loom?
In old Puma models tend to spread oil all around.
Cheers! Eduardo
Post #496220 25th Jan 2016 3:07pm
muddypaws
Thanks - I thought it looked mainly electrical.
There if defo oil coming from it though; will need a closer look
BTW - thanks for the thumbnail tip (I'm only vaguely computer literate) Richard
Defender 90 SVX
Post #496222 25th Jan 2016 3:09pm
I'm going to guess that someone's been a little careless in filling the oil up, spilt some on the top and gravity has taken it down your wiring harness.
Post #496246 25th Jan 2016 4:05pm
muddypaws
I like the overfill option - sounds a cheap fix Thumbs Up
- does seem like a lot of oil for that though. I'll have a ferret around tomorrow; vacuum pump already done last year Richard
Defender 90 SVX
Post #496268 25th Jan 2016 5:39pm
muddypaws
Ok - had another look. I really can't see where the oil is coming from apart from the loom
Here's a picture showing it puddling on the housing underneath - doesn't seem anywhere near the oil filler
 Richard
Defender 90 SVX
Post #496623 26th Jan 2016 2:14pm
Are you sure that it is dripping out of the harness? There is a fair old draught blowing through there with the engine running, and I'd rather expect there to be oil all over the place if it is.
The thingy that it's pooling on is the vacuum pump for the brake servo. There was a well-known problem with the early version of these (and your Defender is old enough to have an early one) since they are pressure lubricated from the engine, but the early shaft seal was single lipped. Once it became sufficiently cruddy, it leaked. Generally the oil went all over the place, since the fan would blow it around (the inside of my bonnet is still oil-stained from this failure) so your modest puddle isn't typical but it is a possibility.
The oil filler is not far away and it is possible that spillage has got onto the harness and tracked down inside.
I presume that if you clean the puddle up it returns? Can you gat any better indication of where it is coming from?
Just be aware that that area is windy enough for oil to leak upwards under driving conditions.
Post #496733 26th Jan 2016 6:12pm
muddypaws
Yup - puddle returns after cleaning.
Never thought of a spray issue bouncing off the loom so will check once more.
- booked in tomorrow as puddles of castrol edge on the drive are getting tiresome!
- will let you know the verdict Richard
Defender 90 SVX
Post #496914 27th Jan 2016 7:36am
muddypaws
And the verdict was...............vacuum pump. Well diagnosed folks
There was a fine oil spray (only visible when the engine was running) that squirted onto the loom making it look like it was leaking. After a few more miles it got worse & became more obvious to see.
I thought the vacuum pump had been done 3 years ago. I assume there is nothing else similar so perhaps it was just bad luck.
Anyway, my Landie has now stopping marking his territory & SWMBO is happy there are to be no more oily footprints on the drive...........for now Richard
Defender 90 SVX
Post #497577 28th Jan 2016 8:29pm
Good result! Thumbs Up
Post #497646 28th Jan 2016 10:33pm
Well called blackwolf Bow down
Post #497800 29th Jan 2016 12:06pm
Rogeo1983
2010 Defender 90 Puma 2.4 CSW Zambezi Silver
Hi folks,
I had this issue two days before Xmas.
But I lost the entire sump contents in 5 mins.
It cost me 295 for a new part from ford..Land Rover wanted 330. If I could have done without it for a while, I could have gone straight to the suppliers and bought one for as little as 40. As this is a very common fault, I have purchased another one in case it fails again.
My friend works in landrover, and he told me that this is so common on the puma engine with both defenders and transits.
Very easy to replace, and be sure to clean out the servo pipe, as it more than likely will be contaminated with oil.
Post #498295 30th Jan 2016 5:30pm
