![]() | Home > Puma (Tdci) > Puma 2.4 oil leak location |
muddypaws Member Since: 22 Jan 2013 Location: Leicestershire Posts: 122 ![]() ![]() ![]() |
Hi
Can someone identify the arrowed pipe that is leaking engine oil please - being more familiar with petrol V8's I'm not sure what this is!! Thanks very much https://www.defender2.net/gallery/albums/u...engine.jpg Richard Defender 90 SVX |
o4dn Member Since: 08 Jan 2010 Location: South West Posts: 562 ![]() ![]() ![]() |
Pic is small because you linked the thumbnail image.
The full size image is here (from your gallery): ![]() Click image to enlarge “A Land Rover immobilized is a moral defeat for the driver and bad publicity for the vehicle, […] it's up to you to do justice to your Land Rover!” - Land Rover Driving Technique. -- 2009 2.4 Puma Defender 90 SW 1979 Land Rover Series 3 88" |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17676 ![]() ![]() ![]() |
The "pipe" you've arrowed is the main engine wiring harness. Nothing should be leaking from it!
In time however you will find that it chafes on the brackets it's secured to, and if not spotted and repaired in time major amounts of smoke will leak from it! |
Eduardo Member Since: 28 Aug 2008 Location: Región Metropolitana Posts: 2110 ![]() ![]() ![]() |
Did you check the vaccum pump located just below the loom?
In old Puma models tend to spread oil all around. Cheers! Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" ![]() Click image to enlarge |
Thanks - I thought it looked mainly electrical.
There if defo oil coming from it though; will need a closer look BTW - thanks for the thumbnail tip (I'm only vaguely computer literate) Richard Defender 90 SVX |
I'm going to guess that someone's been a little careless in filling the oil up, spilt some on the top and gravity has taken it down your wiring harness.
I like the overfill option - sounds a cheap fix
![]() - does seem like a lot of oil for that though. I'll have a ferret around tomorrow; vacuum pump already done last year Richard Defender 90 SVX |
Ok - had another look. I really can't see where the oil is coming from apart from the loom
Here's a picture showing it puddling on the housing underneath - doesn't seem anywhere near the oil filler ![]() Click image to enlarge Richard Defender 90 SVX |
Are you sure that it is dripping out of the harness? There is a fair old draught blowing through there with the engine running, and I'd rather expect there to be oil all over the place if it is.
The thingy that it's pooling on is the vacuum pump for the brake servo. There was a well-known problem with the early version of these (and your Defender is old enough to have an early one) since they are pressure lubricated from the engine, but the early shaft seal was single lipped. Once it became sufficiently cruddy, it leaked. Generally the oil went all over the place, since the fan would blow it around (the inside of my bonnet is still oil-stained from this failure) so your modest puddle isn't typical but it is a possibility. The oil filler is not far away and it is possible that spillage has got onto the harness and tracked down inside. I presume that if you clean the puddle up it returns? Can you gat any better indication of where it is coming from? Just be aware that that area is windy enough for oil to leak upwards under driving conditions. |
Yup - puddle returns after cleaning.
Never thought of a spray issue bouncing off the loom so will check once more. - booked in tomorrow as puddles of castrol edge on the drive are getting tiresome! - will let you know the verdict Richard Defender 90 SVX |
And the verdict was...............vacuum pump. Well diagnosed folks
There was a fine oil spray (only visible when the engine was running) that squirted onto the loom making it look like it was leaking. After a few more miles it got worse & became more obvious to see. I thought the vacuum pump had been done 3 years ago. I assume there is nothing else similar so perhaps it was just bad luck. Anyway, my Landie has now stopping marking his territory & SWMBO is happy there are to be no more oily footprints on the drive...........for now Richard Defender 90 SVX |
Good result!
Well called blackwolf
Rogeo1983 Member Since: 19 Nov 2015 Location: Horsham Posts: 30 ![]() ![]() |
Hi folks,
I had this issue two days before Xmas. But I lost the entire sump contents in 5 mins. It cost me �295 for a new part from ford..Land Rover wanted 330. If I could have done without it for a while, I could have gone straight to the suppliers and bought one for as little as �40. As this is a very common fault, I have purchased another one in case it fails again. My friend works in landrover, and he told me that this is so common on the puma engine with both defenders and transits. Very easy to replace, and be sure to clean out the servo pipe, as it more than likely will be contaminated with oil. |
