Home > Technical > PTO for TDCI |
rodstir Member Since: 17 Sep 2009 Location: telford Posts: 3 |
Hi
Just after some info on the TDCI regarding fitting a PTO to the gearbox. Is it possible? What systems are out there? Anybody completed this mod? Thanks Rodstir |
1st Dec 2010 6:00pm |
AndrewS Member Since: 10 Apr 2007 Location: Hereford Posts: 3709 |
Could it he a Hydraulic winch he has driven off a PTO driven hydraulic pump 130's have feeling's as well you know
1st Dec 2010 8:38pm |
Thanks for the info guys.
i am planning to run a Godiva fire pump in the back of truck. Any ideas how the PTO is engaged is it electronic or manual? |
1st Dec 2010 9:27pm |
22900013A Member Since: 23 Dec 2010 Location: Oxfordshire Posts: 3150 |
SSE went over to electric winches now, not PTO driven, even the last TD5s they had had leccy winches. I have never seen a puma with a PTO winch. 2011 110 USW 1973 Series III 1-Ton 1972 Series III 1-Ton Cherrypicker 1969 IIA 1-Ton 1966 IIA 88" |
25th Dec 2010 12:51pm |
Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 |
First four does PTO driven hydraulic winches and PTO pumps:
http://www.firstfour.co.uk/p0/gearbox-driv...401896.htm http://www.firstfour.co.uk/p0/hydraulic-winches/398014.htm This is the system I will be going for eventually: http://www.firstfour.co.uk/stage-4-type-r-...730194.php with this bumper: http://www.firstfour.co.uk/defender/defend...707674.php |
25th Dec 2010 1:36pm |
nakatanenga Member Since: 12 Nov 2010 Location: Neumarkt Posts: 546 |
Won't fit until you replace the x-member. The LT230 box moved 70mm backwards with the Tdci. So the PTO interfers with the x-member.
AFAIK no fit and forget PTO available for Tdcis Peter WANTED: SII or SIII in max 1.5k |
25th Dec 2010 4:18pm |
once I get the dimensions for the pump I will go underneath and measure it up, The propshaft is my main concern so maybe a lift? Or one of X eng propshafts. The other idea was to cut out a section of x member and reinforce with a plate on the opposite side.
25th Dec 2010 4:26pm |
unfortunately the rear propshaft....
With a special made x-member it should work WANTED: SII or SIII in max 1.5k |
25th Dec 2010 4:32pm |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6112 |
I'll pop over later and ask him if i can take some piccies of it. to be honest i've never looked closely to see if it's hydraulic or electric or mechanical. it looks like a big mechanical husky, but i could be wrong. |
26th Dec 2010 12:41pm |
tacr2man Member Since: 02 Oct 2008 Location: J10 M40 Posts: 20 |
There are two take off points for pto on a LT230 transfer box, in the back and underneath , you can then either fit a prop type mech takeoff or a hyd pump . the undernaeth option is a lot more expensive than the rear , due extra castings etc,
28th Dec 2010 11:29am |
Yannis Member Since: 02 Feb 2015 Location: Oxfordshire / Milan Posts: 408 |
Has anything become available for a hydraulic pump on the 2.2 in the 10 years this thread has been dormant?
20th Jan 2020 8:54am |
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2314 |
2.2, 2.4, TD5... Makes no difference. All Defenders use the LT230 Transfer box which is where the PTO hydraulic pump fits, just run and mount the hoses where you wish.
Quite a few options available from a quick google search. For example http://www.lr-winches.com/Parts/Power_Take...ender_PTO/ > 110 XS Double Cab |
20th Jan 2020 9:22am |
I believe from reading previous posts it’s not so simple on the 2.2/2.4. The transfer box moved back and now the Rear Cross member gets in the way of mounting anything.
20th Jan 2020 9:25am |
From what I understand the rear crossmember doesn't have the PTO drive hole, but if you just want a hydraulic pump and not a shaft to drive a PTO at the rear then it's relatively straightforward
2.2 specific kit https://www.ebay.co.uk/itm/Land-Rover-Defe...2602925846 > 110 XS Double Cab |
20th Jan 2020 9:26am |
