tacr2man wrote:There are two take off points for pto on a LT230 transfer box, in the back and underneath , you can then either fit a prop type mech takeoff or a hyd pump . the undernaeth option is a lot more expensive than the rear , due extra castings etc,
I am happy to be corrected and told that someone has done this, but I don't think the bottom PTO can be fitted to a TDCi due to the lack of clearance for the exhaust. I suppose that it might be possible to create a custom exhaust that fits, but with the standard system there is simply not enough room for the PTO. There should be no particular problem fitting the standard rear PTO.
20th Jan 2020 9:39am |
