![]() | Home > Puma (Tdci) > Cold weather rattle in front right of dashboard. |
fordy103 Member Since: 22 Dec 2010 Location: preston lancs Posts: 85 ![]() ![]() |
also have this really annoying issue! taking mine to dealers tommorow to shout at them!
james |
TC Member Since: 21 Nov 2010 Location: Gloucestershire Posts: 715 ![]() ![]() |
Obviously something not sorted cross variants as my 03 plate TD5 has started doing it!
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4766 ![]() ![]() |
Have a look at the rubbers on the bonnet hinges. They can wear allowing slight movement giving a noise like this. See if there is any movement in the bonnet.Mine needed rubber inserts. 1982 88" 2.25 diesel
mines done 5000 miles from new so nothing should be worn in my opionion!!
BarneyRubble Member Since: 08 Mar 2010 Location: Naphill Posts: 103 ![]() ![]() ![]() |
I've got a rattle too, but I've only done 2000 miles.
Mine sounds like a wire or loom rattling when going over bumps (so all the time). When the weather warms up above freezing I was going to try and have look. Barney D4 - 2016 Graphite, Montalcino Red Written Off - 2010 90 Hard Top, Stornoway Grey |
BigWheels Member Since: 21 Mar 2010 Location: Somerset Posts: 1405 ![]() ![]() ![]() |
Doesn't sound metallic in any way, & unless its stethoscoping, sounds like happening inside the vehicle. Land Rover Defenders. 67 years heritage, minimal appearance changes, still going strong all over the world. Not a fashion vehicle, but fashionable to own. Made for the needy, not the greedy. Ta ta Defender |
