Home > Puma (Tdci) > "idle jack"
Page 2 of 2 <12
nickhodgson
Hi Blackwolf
For all the situations you describe I agree the anti stall is great. I especially like it towing my trailer or driving up my ramp in low range at idle as well.
My point was about the Puma engine "making a fuss" (increased vibrations) as it tries to increase the revs when you are in the wrong gear for the puma when in the older 300tdi you can get away with it and the engine still runs smoothly. It definitely feels not good for the engine or car in the Puma when you are in the wrong gear but the 300tdi seems pretty happy at very low revs - no power but does run smoothly.
Nick 1995 300tdi Defender 90 P/UP
2011 Puma Defender 130 D/C
2000 300tdi Defender 110 P/UP
2015 Discovery 4 SDV6 HSE
Post #494293 20th Jan 2016 5:18am
lohr500
Thanks for the explanation Blackwolf Thumbs Up
Post #494297 20th Jan 2016 6:10am
Smurph
2012 Defender 110 Puma 2.2 SW Keswick Green
I agree with nickhodgson 100%. The Puma wants to drive itself in certain situations . I disconnected the idle jack and much prefer its behaviour in low range.....but still prefer the Tdi in the bush. On road different story.
Post #494310 20th Jan 2016 8:22am
Cupboard
One thing that I don't think has been mentioned about Idle Jack is how it knows to use it.
There isn't a switch telling the ECU that you're in 1st or reverse, it guesses based on wheel speed and whether you're in low range. As a result it sometimes accidentally engages Idle Jack if you're in low and not in 1st.
Post #494420 20th Jan 2016 1:29pm
That has been discussed in other similar threads in the past - I know, because I have questioned this very question (if that makes sense).
You are right, Idle Jack will quite often activate in ANY low range gear .
As you say, all the ECU knows is that low range is selected, the engine speed, and the aggregate wheel speed (which equates to road speed assuming no loss of traction). You may not like the feature (or indeed you may), but you can't deny it's clever!
Post #494436 20th Jan 2016 2:09pm
Page 2 of 2 <12
