Home > Maintenance & Modifications > TD5 Intermittently Running Rough |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2222 |
Do a search on how to check if the wastegate is seized.
Steve 02' 110 TD5 Double Cab Rebuild Thread |
15th Jan 2016 5:38pm |
Mash Member Since: 09 Feb 2015 Location: Guernsey Posts: 1674 |
Have you checked the ecu loom for oil impregnation? 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
15th Jan 2016 5:40pm |
danridge Member Since: 28 May 2013 Location: Bath Posts: 438 |
Cheers Steve - It's not turbo related. Its like a cylinder inst firing. Turn the engine off and back on immediately its cured (till the next time) |
15th Jan 2016 5:44pm |
How do I do that Mash? cheers |
Found this - thanks for the point in the right direction
http://www.web-rover.co.uk/nav.php?p=td5kb/oilharness |
15th Jan 2016 5:48pm |
Treebeard Member Since: 27 Jun 2012 Location: Forest of Dean Posts: 40 |
Geobloke put up this helpful summary for a rough running td5 on 27Dec.
Click image to enlarge |
15th Jan 2016 6:11pm |
Thanks Treebeard - have guy got a link to that thread?
15th Jan 2016 10:25pm |
http://www.defender2.net/forum/topic41632.html
I'm sure that there are plenty of others on the same topic as well |
15th Jan 2016 11:26pm |
Thanks mate
15th Jan 2016 11:41pm |
pj2106 Member Since: 20 Dec 2012 Location: Huntingdon AKA The Shire Posts: 1500 |
Definitely sounds like a injector loom issue
Check red plug under drivers seat for oil if present fit a new loom easy to do yourself and costs about 40-50£ 2008 110 2.4 XS Utility (Hagrid) 2002 90 TD5 Hardtop (Sully) Sold 1998 300TDi D1 (Billy) Sold |
15th Jan 2016 11:49pm |
