Home > Maintenance & Modifications > TD5 Intermittently Running Rough
danridge
United Kingdom 2004 Defender 90 Td5 XS CSW Java Black
My TD5 has started to intermittently run rough. It feels under powered and feels and sounds like it's not running on all cylinders. Curiously a simple engine switch off and restart cures the problem. I do the same route often and know exactly where it's going to happen which is approx 30 mins into the journey.
I posted this on a Facebook Landy group and got the following replies. The second being preferred Shocked
1) Mine did the same got slowly worse over time, combination of fuel leaking into the oil & the dreaded oil along the wiring loom into the ecu !!
2) Take rocker cover off, there is lead with plugs on it, you can replace it, its not expensive and easy to do.
Thoughts? Thanks.
Post #492667 15th Jan 2016 4:31pm
rallysteve
Do a search on how to check if the wastegate is seized.
Post #492672 15th Jan 2016 4:38pm
Mash
Guernsey 1998 Defender 90 300 Tdi HT Nato Green
Have you checked the ecu loom for oil impregnation? 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
90 V8 - Maggie http://www.defender2.net/forum/topic42564.html
110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html
52HG25 lightweight https://www.defender2.net/forum/topic72342.html
D3 Hse - Fiona
Capri 2l S - Anna
Think I might have a problem............
Post #492674 15th Jan 2016 4:40pm
danridge
Steve
Cheers Steve - It's not turbo related. Its like a cylinder inst firing. Turn the engine off and back on immediately its cured (till the next time)
Post #492676 15th Jan 2016 4:44pm
danridge
How do I do that Mash? cheers
Post #492677 15th Jan 2016 4:44pm
danridge
Found this - thanks for the point in the right direction Thumbs Up
http://www.web-rover.co.uk/nav.php?p=td5kb/oilharness
Post #492680 15th Jan 2016 4:48pm
Treebeard
United Kingdom 2005 Defender 110 Td5 CSW Chawton White
Geobloke put up this helpful summary for a rough running td5 on 27Dec.
Post #492690 15th Jan 2016 5:11pm
danridge
Thanks Treebeard - have guy got a link to that thread?
Post #492782 15th Jan 2016 9:25pm
Treebeard
http://www.defender2.net/forum/topic41632.html
I'm sure that there are plenty of others on the same topic as well
Post #492799 15th Jan 2016 10:26pm
danridge
Thanks mate
Post #492809 15th Jan 2016 10:41pm
pj2106
United Kingdom 2008 Defender 110 Puma 2.4 USW Stornoway Grey
Definitely sounds like a injector loom issue
Check red plug under drivers seat for oil if present fit a new loom easy to do yourself and costs about 40-50£ 2008 110 2.4 XS Utility (Hagrid)
2002 90 TD5 Hardtop (Sully) Sold
1998 300TDi D1 (Billy) Sold
Post #492814 15th Jan 2016 10:49pm
