Home > Td5 > Wiper mechanism |
srod Member Since: 20 Mar 2015 Location: Argyll Posts: 190 |
I don't think so.
I followed this guide: https://www.landyzone.co.uk/land-rover/wip...wal.99743/ Every screw seemed to be a different size, so keep track of what comes off where. |
14th Jan 2016 11:57am |
tasr12 Member Since: 09 Jun 2013 Location: Dorset Posts: 228 |
Typical! Ordering parts so just need to find the time now!
Thanks for the link - I found that one late last night - think it's a 300Tdi but still useful. 2002 110 CSW TD5, Zambezi Silver 1995 110 CSW 300TDi - SOLD |
14th Jan 2016 12:20pm |
Yes - and there are some differences - infact I gave up trying to get the drivers side one out!
However (someone or some googling will need to confirm) - I think the difference lies between '02, and '03, the wheel box shaft is slightly longer (mine is an '03) so you may be lucky... check before ordering bits. |
14th Jan 2016 12:25pm |
Luck never seems to be close at hand but we will see!
Regards, Tom. 2002 110 CSW TD5, Zambezi Silver 1995 110 CSW 300TDi - SOLD |
14th Jan 2016 1:30pm |
landroverdiver Member Since: 13 Jun 2009 Location: Renfrewshire Posts: 193 |
You need to take the dash out to remove the wheel boxes, the spindles are too long to do anything else
If you have to go to this length, replace with new, only use genuine LR parts, and grease well |
14th Jan 2016 4:05pm |
Cheers. 2002 110 CSW TD5, Zambezi Silver
14th Jan 2016 4:15pm |
Tiger Member Since: 06 Jul 2012 Location: Wales Posts: 2265 |
You don't need to take the dash out.
Did mine just by taking the top pad off, takes some double jointed spannering but can be done. Replaced both wheel boxes and the drive cable Housing Assy - Wiper Motor DKU500010G 2 Wiper Rack DLE000010LR 1 Arm Assy - Wiper DKB000061PMD 2 Tube PRC2471 1 Click image to enlarge |
14th Jan 2016 4:33pm |
Tiger - thanks for that. I'm going to give it a go. Should hopefully be able to pick up 2 x wheel boxes and the rack locally tomorrow. How long did it take you? Bar the double jointed spattering any other top tip for your method? How did you get the old rack out and then feed the new rack in to place and connect into the motor? 2002 110 CSW TD5, Zambezi Silver
1995 110 CSW 300TDi - SOLD Last edited by tasr12 on 14th Jan 2016 9:48pm. Edited 1 time in total |
14th Jan 2016 7:31pm |
barbel jim Member Since: 12 Dec 2012 Location: Northants Posts: 1431 |
Th drivers side is the Pig
You'll have to take the instrument cluster out to remove the demister as the wheel box is behind it. You dont need to remove the bottom dash, but thats the correct way of doing it. The wheel box on the later type, won't go back far enough, but will with a bit of persuasion from some stilsons Alternatively yes as a quick fix rotating the wheel boxes works, just mark them first before you pull the drive cable, so as you can rotate 180 degrees efficiently, and check they are correct when reassembled. Your washers sounded like mine, caused by the gears jamming adding strain to the motor. |
14th Jan 2016 8:21pm |
Jim, how do you pull the drive cable out with the motor in situ?
Did the rotate work or did you need a new motor in there? 2002 110 CSW TD5, Zambezi Silver 1995 110 CSW 300TDi - SOLD |
14th Jan 2016 9:49pm |
Yep the rotate worked a treat for me👍 You have to remove the wipermotor, but leave attached to drive cable and just pull slowly out. You will have to split the wiper boxes as Tigers picture ( 2 8mm nuts) so as the solid guides come out, and remember to take your wipers off ! 4 hours ish ?? 👍
14th Jan 2016 10:35pm |
It's not a hard/complex job just a bit of a
Takes a while but with 12 cups of tea it's do-able |
15th Jan 2016 1:36am |
Jim, thanks for that - impressed you got the wiper motor out without removing the dash! Square peg round hole springs to mind! I split the paassenger sides straght away when I was investigating - just need to get at the drivers side now. Thanks. 2002 110 CSW TD5, Zambezi Silver 1995 110 CSW 300TDi - SOLD |
15th Jan 2016 7:34am |
And the rest if I get around to it this weekend! 2002 110 CSW TD5, Zambezi Silver 1995 110 CSW 300TDi - SOLD |
15th Jan 2016 7:35am |
