Home > Puma (Tdci) > Puma Rear diff noises
Page 1 of 3 123>
Marius
South Africa 2011 Defender 110 Puma 2.4 SW Keswick Green
Just got my 110 Puma. 1000km and there seem to be noises on the rear diff when changing gears (mostly between 1 st and 3 rd).
Almost sound like play on the teeth. When I engage the gear it "klangs" like things banging together - thus me thinking some play....?
The question is when should I take it in to get looked at? What other symtoms should I be looking at/observing.
Or is this this diff in any case just a noisy diff? Should be very concerned?
Post #49202 21st Dec 2010 6:54am
Naks
Re: Puma Rear diff noises
Marius wrote:
Just got my 110 Puma. 1000km and there seem to be noises on the rear diff when changing gears (mostly between 1 st and 3 rd). Almost sound like play on the teeth. When I engage the gear it "klangs" like things banging together - thus me thinking some play....? The question is when should I take it in to get looked at? What other symtoms should I be looking at/observing. Or is this this diff in any case just a noisy diff? Should be very concerned?
Marius, am having the same issues on my 90 (14Kkm), just took it to LR N1 City. The mechanic who came on a drive with me says that only they have only seen the rear diff problem on the 110.
I'm waiting for their call as to what the problem is, my indie mechanic seems to think that the 3rd gear is a bit loose on the shaft, causing all the clunking when going in and out of 3rd.
Post #49205 21st Dec 2010 8:31am
o4dn
France 2009 Defender 90 Puma 2.4 SW Alaska White
I got my rear diff replaced under warranty on my 90 just a few months ago. So that's not just the 110. No more clunking since then, works like a charm now Smile
Post #49208 21st Dec 2010 9:02am
Marius
In the new year I'm gonna have to go get this sorted out.
Post #49209 21st Dec 2010 9:09am
MK
are you sure the clunk is from the rear diff? I would rather wait until party is over. Make the dealer to take the rear prop off (either from the parking brake or rear flange). If the slack is not from the diff then you have probably a clutch issue. Puma 110" SW
Post #49215 21st Dec 2010 9:36am
Marius
The clunk is just after shifting somewhere at the back (diff I would say). If you take ALLOT!! of care shifting shoftly it is not as pronounced, but no one can drive that that.
Post #49218 21st Dec 2010 9:47am
MK
I know what you mean. Not being able to look at I would say it is eirther the diff (weird) or wacked coil springs from the clutch. Take it to a "good" dealer who knows what they are doing.
I heard LR produced a batch of new faulty clutch discs (yes! the new version).
Anyway, nothing to worry about unless you plan to drive up to tanzania these days. Puma 110" SW
Post #49219 21st Dec 2010 10:01am
Marius
I wonder if this could be a combination of Rear diff and clutch? Allot of guys I read about has allot of rear diff problems - some on their 4th diff after 40k
Post #49224 21st Dec 2010 10:55am
heinrichnel
Namibia 2008 Defender 110 Puma 2.4 XS CSW Stornoway Grey
Get the rear diff replaced a.s.a.p. I am on diff # 7 already and only 30K on the clock. The problem I am having is becasue my car is more than 1 year old and has more than 20K, LRSA will not replace it with a new diff and keep on replacing it with a recon ones! I only found this out after diff # 7, now I am fighting this and want a new one!
Post #49235 21st Dec 2010 2:50pm
Merlin
Had a new rear diff at 10,000 miles, but it started making noises at 5k. The stealership just didn't believe me. Got a new one but at 36,000 the rear UJ started to make noises too. Got that changed as well. Is there a connection? Don't know but you might like to monitor yours.
Merlin
Post #49243 21st Dec 2010 3:53pm
Naks
So I had a long chat with Peter from N1 City - the old mechanic who only works on Defenders.
During the test drive he agreed there was excessive play in the drivetrain, and he says he looked at the propshaft, rear driveshafts and made sure everything was tightened as required. He also says that due to the different gearbox and clutch on the Puma, there is more drivetrain backlash than on the Td5. Confused
There was definitely less clunking when I drove home, I'll see in the following month how that holds up. The landy is due for service on Feb 2nd, so will tell them to look at it again if needed.
Post #49319 22nd Dec 2010 7:25am
Marius
I will go in after the new year to get it looked at as well.
Will keep you guys up to date as to whether it was clutch/diff or combo.
Post #49327 22nd Dec 2010 9:00am
AndrewS
Are the 4 bolts on the front of the rear prop tight ? 9/16 spanner Thumbs Up 130's have feeling's as well you know Smile
Post #49330 22nd Dec 2010 9:11am
Marius
Andrew, I will have a look this afternoon. I assume it's at the location where the shaft enters the rear diff?
Post #49362 22nd Dec 2010 12:22pm
AndrewS
No, where it joins the transferbox/park brake drum. As you are under the vehicle check all the prop bolts there are 4 at each end of each prop Thumbs Up 130's have feeling's as well you know Smile
Post #49367 22nd Dec 2010 1:12pm
Page 1 of 3 123>
