Home > Puma (Tdci) > Stinky exhaust |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6298 |
Thanks very much for that and I generally agree - I'll probably change them to be sure but wouldn't unburnt fuel be black smoke?
in terms of the wobble I think you're right you would be this but unfortunately I don't think this is the cause but I will look further into it. |
7th Jan 2016 8:56pm |
Riccarton Member Since: 10 Aug 2015 Location: Gods' Own Country Posts: 280 |
You should be able to check them with a diagnostic check rather than a physical swap. An indy with the right kit should be able to check for you - around here it'll be less than £35 so I wonder bother getting the spanners out for that.
The plus to this route is if it's a wiring issue you'll be able to check but if you simply swap and there is a wiring fault you won't see a difference and presume there was nothing wrong with the old ones. Oh, black smoke for poorly burnt fuel whereas white smoke for raw diesel dumped down the exhaust (or summet like that). Good luck & I hope 2016 is the end to all your problems |
7th Jan 2016 9:04pm |
Another thought would be disconnect all of them. I'm lead to believe my another forum member they start fine without the glow plugs?
7th Jan 2016 9:38pm |
Jukathy Member Since: 25 Jan 2015 Location: Berlin Posts: 170 |
a modern diesel engine + blanked EGR? W/ modified SW only ... Hence otherwise
10th Jan 2016 11:05am |
Sorry mate don't understand (as usual)
10th Jan 2016 8:01pm |
If you're gonna blank your EGR exchange the software on your ECU, too.
11th Jan 2016 1:14am |
egr blanked and software adjusted to suit.
11th Jan 2016 8:19am |
Clean all injectors, try better software.
Cheap software does not take into account the gas coming from the EGR in order to oxidate once more. Like 2CO + O2 -> 2CO2. The relationship is not correct any more i.e. too much diesel and everything filthy inside the engine. |
11th Jan 2016 4:23pm |
thanks very much. I don't think it's the software as it seems to have come on all of a sudden (and yes I do appreciate the temp have dropped).
I use quite a bit of Redex and as such would like to think the injectors are clean but I guess they could be faulty (or one could be)? |
11th Jan 2016 4:44pm |
The King
[/url][/code] |
11th Jan 2016 10:28pm |
So glow plugs.
Do I buy 4 from LR at @£16 or a set off amazon for apporx £20? |
12th Jan 2016 9:21pm |
DEF110DCPU Member Since: 06 Aug 2008 Location: ODK Posts: 18 |
since a couple of weeks I also did decat and change midpipe, and really I also have a stinky exhaust now - I also have the EGR blanked and pull the plug out (not yet remapped for this part) the exhaust smells terrible - when I put it in our home garage I need to keep windows open for at least 15 minutes... I didn't try it without the blanking plate and EGR plugged in... maybe it is better |
2nd May 2017 8:09pm |
diduan Member Since: 13 Oct 2016 Location: Central Balkan Posts: 260 |
Decat and EGR blanking (via software) since two years, small amount of white smoke on start, but nothing special. I can let the engine run for a while in thd garage, no need to vent afterwards. Actually i find it smells fine
I also use redex from time to time. If i put too much it smokes more (white). Defender 110 SW MY2011 2.4tdci decat, no EGR Jeep Wrangler YJ 1990 4.0. Front 78' Dana 60, Rear CUCV 14 bolt |
3rd May 2017 7:45am |
pannawonica Member Since: 21 Nov 2010 Location: Clackline Western Australia Posts: 568 |
I have all the usual mods, similar too most ! Diesels do sink up a bit on cold morning with no breeze. Normal really, but I soon get going driving too get the job done not sparing the horses. This makes the rings bite and clean the bores, they are better for doing so hard work. They love it !
3rd May 2017 11:46am |
