Home > Puma (Tdci) > Stinky exhaust
caribcat
2013 Defender 110 Puma 2.2 USW Aintree Green
Stinky exhaust
Since I removed the cat and mid box the exhaust really stinks, can't describe it really but notice smelly exhaust hanging around when I run it for a while before I drive on cold mornings. Don't quite understand it.
Post #55671 29th Jan 2011 11:58pm
fekete
I've got the same set up with no smells ? is it sealed properly NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #55678 30th Jan 2011 12:28am
K9F
Rolling with laughter If you've got your internal fan setting above 1 it could be that your breath is being blown back into your face! Have you tried brushing your teeth before setting off! Try a mint imperial or two!!! Rolling with laughter If you go through life with your head in the sand....all people will see is an ar5e!!
Post #55684 30th Jan 2011 2:30am
caribcat
We have 2 identical vehicles in the company with the same conversion, they both smell the same. The job was done by Mills 4x4 here in North Wales, and I think they are pretty switched on.
Post #55746 30th Jan 2011 5:44pm
fekete
Strange one that then...anybody else having this problem ? NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #55748 30th Jan 2011 6:09pm
Caterham
Original exhaust b I do have blanked egr. Smell / fumes seem to have increased recently together with a slight wobble on start up in the morning only?
Anything I should be looking out for?
Will be changing fuel filter tonight.
Post #488873 5th Jan 2016 4:41pm
5 year post revival !!!!!
I haven't seen Caribcat for a while !!! Too busy with work I expect..kudos to him Cool
Post #488878 5th Jan 2016 4:51pm
Caterham
So it gets worse.
I thought i'd seen white smoke the other morning along with wobble but wasn't sure so didn't mention it. Tonight however got the wobble and white smoke on start up.
Sad
An thoughts...sticky injector?
Post #489653 7th Jan 2016 6:06pm
Cupboard
Are you sure it's not just because the weather's got colder?
Mine does it, if I start from cold then after about 20 seconds I get a small white cloud round the exhaust for a bit and it's quite smelly. Soon sorts itself out.
Post #489677 7th Jan 2016 7:18pm
Caterham
Pretty sure it's not that but thanks for the suggestion all the same.
might not be but think it's linked to the wobble. never noticed it smelly so much before and have had it through 5 previous winters.....and it didn't wobble in the previous winters either.
Post #489680 7th Jan 2016 7:21pm
tazmarkuk
England 2000 Defender 110 Td5 HT Chawton White
Had a smell over the last 4 years, I too would get white smoke in the colder months on start up but would go during the warmer months. the smell I put it down to the fact the cat had been removed. However, start of this Autumn mine too started to get worse, really fumey, this later transpired to be a failing turbo. The turbo was replaced with a new unit and there was an improvement in the smell and fumes but now the engine has started breathing, Started to wonder if this has caused more issues than first diagnosed. Yet to sort a compression test kit.
Post #489693 7th Jan 2016 7:45pm
Caterham
of course. white smoke lack of air/fuel and black would be a sticky injector / over fuel?
F ! this is really p 'in me off.
thank you all the same.
I'm not sure it's the turbo - if it is this one hasn't lasted too long. my intermittent problem which I've always though was something to do with poor fuel / air delivery seems to be getting worse albeit still intermittent.
Big Cry
Big Cry Big Cry Big Cry Big Cry Big Cry Big Cry Big Cry
Post #489697 7th Jan 2016 7:59pm
Happyoldgit
Now you've done it taz.... Steve.
http://forums.lr4x4.com
Post #489700 7th Jan 2016 8:04pm
Caterham
Steve,
I'm glad you're around....helps keep me going at times this.
Its kinda reassuring to know there's owners out there not having too many def probs.
just come back in from freezing me nads off having a quick look under the bonnets for any little tells (none) and while out there gave the drivers door lock another good dose of WD40 in the hopeless attempt at getting the central locking to work again
Big Cry
Post #489708 7th Jan 2016 8:13pm
Caterham
injector stuck closed / partially blocked?
f !
there's a thought - perhaps between now and November I could turn it into an F in big Firework ?
Post #489713 7th Jan 2016 8:23pm
