Home > Maintenance & Modifications > M1 Protector or ACF50?
Orangesofa
United Kingdom 2013 Defender 90 Puma 2.2 SW Keswick Green
Are these products the same?
Is one better than the other? (ACF is more expensive but that doesn't always mean better...) Phil
Post #489887 8th Jan 2016 10:04am
ACF 50 is great and relied upon. It works, simple as that. Thumbs Up
Post #489904 8th Jan 2016 11:00am
Orangesofa
Same could have been said for the Willys Jeep but didn't stop Maurice Wilks taking the principle and coming up with something better... Wink Phil
Post #489907 8th Jan 2016 11:04am
JOW240725
I was just this morning reading 'Funrover' "Defender 90 TD5 Rebuild / Tribute Build Thread" and coincidentally with a photo states he used "M1 Corrosion protector (like ACF50, but cheaper)".
I've only used ACF50 bought off Amazon for around £17 per can so not cheap.
link here http://www.defender2.net/forum/topic40309-15.html
Post #489918 8th Jan 2016 11:36am
Vipergts
I smothered my Dodge Ram when it was brand new a year ago, all over the suspension and underside. Dirt washes off. I have re applied it twice in that period but all the nuts and bolts inc callipers and fittings are all still like new.
Great stuff and the even do a new one "Corrosion Block" thicker and the fella recommended this for the Landy
Post #490046 8th Jan 2016 7:03pm
mse
Acf 50 is cheap I pay £9 from the place that does the annual inspection on the plane, although I think it might be £11 next time Mike
Post #490154 9th Jan 2016 1:23am
JMG
United Kingdom 2014 Defender 90 Puma 2.2 XS CSW Stornoway Grey
Can the ac50 be sprayed onto the paintwork and left on to protect paint over worst of the winter?
Post #490178 9th Jan 2016 9:13am
Screbble
I spray ACF 50 all over the truck and it inevitably ends up on the paint. Ideally you do need to get it in those seams around the rear tub. I do spray specifically in on some areas of the painted bodywork and it seems to do the trick with very little corrosion is evident. Certainly makes it easier to clean.
It wipes off easy enough anyway, and I read that it's perfectly safe on the paint, but there are plenty of knowledgable and experienced forum members who will point you in the right direction.
Sadly, I enjoy the periodic rivet head ACF treatment.
Note to self - must get a life!
Post #490310 9th Jan 2016 4:36pm
mse
I sprayed it in a few areas and as mentioned it goes on the paint.
I couldnt work out all the best places to spray it though...i sense a guide comping on Whistle Rolling with laughter Mike
Post #490320 9th Jan 2016 5:09pm
Clive
United Kingdom 2004 Defender 90 Td5 X-Tech LE Zambezi Silver
Post #490366 9th Jan 2016 6:46pm
mse
Yeah seen that its just not good enough Embarassed Laughing Mike
Post #490503 10th Jan 2016 12:44am
