Home > Maintenance & Modifications > M1 Protector or ACF50? |
Orangesofa Member Since: 10 Oct 2014 Location: Somerset Posts: 214 |
Are these products the same?
Is one better than the other? (ACF is more expensive but that doesn't always mean better...) Phil |
8th Jan 2016 10:04am |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20468 |
ACF 50 is great and relied upon. It works, simple as that.
8th Jan 2016 11:00am |
Same could have been said for the Willys Jeep but didn't stop Maurice Wilks taking the principle and coming up with something better... Phil
8th Jan 2016 11:04am |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7907 |
I was just this morning reading 'Funrover' "Defender 90 TD5 Rebuild / Tribute Build Thread" and coincidentally with a photo states he used "M1 Corrosion protector (like ACF50, but cheaper)".
I've only used ACF50 bought off Amazon for around £17 per can so not cheap. link here http://www.defender2.net/forum/topic40309-15.html |
8th Jan 2016 11:36am |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5038 |
Acf 50 is cheap I pay £9 from the place that does the annual inspection on the plane, although I think it might be £11 next time Mike
9th Jan 2016 1:23am |
JMG Member Since: 16 Apr 2014 Location: Surrey Posts: 222 |
Can the ac50 be sprayed onto the paintwork and left on to protect paint over worst of the winter?
9th Jan 2016 9:13am |
Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 2108 |
I spray ACF 50 all over the truck and it inevitably ends up on the paint. Ideally you do need to get it in those seams around the rear tub. I do spray specifically in on some areas of the painted bodywork and it seems to do the trick with very little corrosion is evident. Certainly makes it easier to clean.
It wipes off easy enough anyway, and I read that it's perfectly safe on the paint, but there are plenty of knowledgable and experienced forum members who will point you in the right direction. Sadly, I enjoy the periodic rivet head ACF treatment. Note to self - must get a life! |
9th Jan 2016 4:36pm |
I sprayed it in a few areas and as mentioned it goes on the paint.
I couldnt work out all the best places to spray it though...i sense a guide comping on Mike |
9th Jan 2016 5:09pm |
Clive Member Since: 21 Mar 2014 Location: Littleborough Posts: 467 |
9th Jan 2016 6:46pm |
Yeah seen that its just not good enough Mike
10th Jan 2016 12:44am |
