Home > Puma (Tdci) > How to engage low range
Page 3 of 3 <123
Jimmoore
Scotland 2016 Defender 110 Puma 2.2 Landmark LE Santorini Black
I recently went on a Land Rover experience day and they talked me through all of this stuff.
I had Low box and Diff lock on pretty much all of the time I was on the circuits... including a 2 hour trek up in the estates high over the A9 just outside Dunkeld.
I feel a lot more confident about the diff controls now but I think I will go back for a refresher.
If for nothing else but to get the chance to sling the centre's Defender around in the mud, water and over the rocky stuff.
Lunch was a bit ropey tho...
Post #488718 5th Jan 2016 2:34am
oburrill
United Kingdom 2013 Defender 110 Puma 2.2 SW Corris Grey
Land Rover "Under Control" training video is useful.
Post #489074 6th Jan 2016 6:41am
jst
As taught by LRE, current teaching, by the book is:
engine running,
foot on brake
clutch in
main box in any gear.
T box to other range
if tbox lever stops in neutral position, whilst keeping foot on brake slowly start to lift the clutch whilst simultaneously applying pressure to the tbox lever (in the direction of the range you wish to select)
once lever starts to move to desired range clutch goes back in
confirm range selection (as you can can partial gear engagement) by keep foot brake pressed, and applying pressure to lever to hold in the range and slowly lift clutch until vehicle wants to move.
advantages are it will always work (unless mechanical problem is evident), vehicle doesnt need to move, its safe
ref CDL - LRE teaching is engage it if you think there is the chance of loosing traction when assessing the ground ahead prior to driving the ground.
bear in mind you only have one wheel drive guaranteed in a Def unless CDL is in. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #489091 6th Jan 2016 8:27am
jst wrote:
engine running,
foot on brake
clutch in
confirm range selection (as you can can partial gear engagement) by keep foot brake pressed, and applying pressure to lever to hold in the range and slowly lift clutch until vehicle wants to move. ...
Not particularly meaning to pick nits, but that will make nasty noises!
Remember "clutch in" = engaged, "clutch out" = disengaged. This has been the definition of the terms since the invention of the motor car (actually since the invention of the first dog clutch which pre-dated the car by many years).
It is however obvious from the context what you mean.
Post #489155 6th Jan 2016 11:43am
discomog
Blackwolf is technically correct so I guess for "Clutch in" read "Clutch pedal down" but as he says it's pretty obvious what was meant. Defender 90XS SW
Mini Countryman Cooper S
Morgan Plus 8
Post #489167 6th Jan 2016 12:03pm
jst
thanks for pointing out Very Happy Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #489322 6th Jan 2016 8:53pm
Rattys
United Kingdom 2015 Defender 110 Puma 2.2 USW Santorini Black
Cake, one other thing to practice and get comfortable with is disengaging the diff lock. I've had a Defender Tdci 2.2 that was a pig to disengage. As it alright but not ideal to be in low box on tarmac, you definitely do not want to have the diff lock engaged when there is grip such as tarmac. Find your self a gravel lane and practice swapping from high to low rather than on your drive, then when you are comfortable try engaging the diff lock and disengaging it as if it sticks you could be stuck as its not healthy to drive on tarmac with it engaged. If it wont disengage try reversing 6 feet and trying again, if this doesn't do it try reversing and putting some lock on the steering, it will come out just be patient,
I'm a big fan of Tom Sheppard but he writes with 100,000's of mile of experience or if you like practice. My own experience is that you get stuck for two reasons, lack of traction or you be come grounded, which is essentially the same thing. So you should switch to low box when you leave the tarmac and if the terrain looks very loose or muddy ie there is chance of wheel spin, put in the diff lock before you drive the section. As the guys say get in with a local club or go on one of the organised tours to start with, the guide and others on the tour will be great to chat too and you can find out how they tackled each section. When you feel more comfortable you can stay in high box etc. as i am sure some of the very experienced guys on here do because they've had plenty of practice. I in fact will be out practicing my skills this week end. 1954 86" - makes any green lane seem as long as the trans american high way
2015 110 Utility - will have to go and travel the trans american highway
Post #489542 7th Jan 2016 11:59am
Cake
Thank you.
yes I need to practice and the land I shoot on is nothing special, just fields and small hills.
I think my lack of experience and the torrential rain softening up already soft farm land is what finally caught me.
I tried to put it in low range but I didn't know and out panic I did something similar to what's needed but obviously not quite.
I tested that it worked on my driveway as I would say its never been used in low range.
I tried locking the diff also to ensure that was free but I couldn't get it to move to the left so either im doing something wrong or its need freeing up.
I will give it a test in the next couple of weeks and hopefully get through with no issues Smile
Post #489579 7th Jan 2016 2:10pm
Jimmoore
The LR Experience is definitely a good place to start... as mentioned before they cover a lot of aspects of the Low and High Box as well as Diff Lock... and the Diff Lock unwind which I had to do after coming off the off-road route,
Post #489601 7th Jan 2016 3:13pm
jst
why not? ideal for anything wanting low speed control. reversing a trailer for example. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #489739 7th Jan 2016 9:31pm
jst
ref difflock and getting rid of wind up.
in essence there was too much traction to front and rear axles on the last few turns made.
you have made front and rear axles rotate the same amount with the middle diff locked.
the vehicle now has wind up between the front and rear axles as the rear axle cut the corners slightly and needed to travel a shorter distance than the front axle but couldn't
moving the diff lock lever to the RH side will inevitably leave the diff lock light on and hence engaged.
now try reversing lock to lock which means the rear axle is now the front axle which is now travelling over a greater arc compared to the front axle which is now the rear axle (as your going backwards) hopefully the two will equalise and the diff lock will unlock.
OR alternative method which is what i always use.
You have some wind up.
Diff lock lever to the RHS to allow the middle diff lock to unlock (but it hasnt yet)
Hand brake on (lock rear prop)
in reverse (assuming diff lock wind up was created by fwd movement which is 99% of the time) slowly lift the clutch until its just starting to engage.
by doing this front prop is rotated the opposite was to which wind up occurred, rear prop is stationary so system will equalise.
advantage - you dont have to move the vehicle.
Hope this helps
as before and mentioned by others, all part of LRE 1.2 day Def and Level1 courses and Level2 refresher elements. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #489743 7th Jan 2016 9:39pm
Page 3 of 3 <123
