![]() | Home > Puma (Tdci) > Intermitent Rear wiper |
Not mine
![]() VERY EASY MOD!!!! Have you a standard/original Land Rover wiper ECU in your hand? ![]() ![]() ![]() ![]() The green-white cable of position 6 of the base must be put on position 1 ![]() ![]() ![]() Test it.............................. ..............job done Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
nicks Member Since: 21 Aug 2008 Location: south coast Posts: 469 ![]() ![]() ![]() |
Is that red one, the one you replace with the VW 99 relay for variable front wipers?
Yesss Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
Zinke Member Since: 27 Jan 2009 Location: Scunthorpe Posts: 670 ![]() ![]() ![]() |
Very good!
Been wondering about that ever since i replaced my front relay, just havent had time to work out which wire goes where! Just one question, do you need power to pin 1 and 6 or just power to pin 1? Many thanks. Pete. |
SiWhite Member Since: 19 Jan 2010 Location: North Hampshire Posts: 455 ![]() ![]() ![]() |
I'm doing this in the morning, if I can understand the instructions...
So the green and White wire comes out, then I get lost. Which wires are joined together? Is a new wire added anywhere? My blog - www.anacreinhampshire.blogspot.co.uk 110 TD5 BuildHERE - sold! 110 Tdci Build HERE - sold! Passat Alltrack - 4x4, auto, 45mpg, gloriously comfortable - but not a Defender! |
just to pin 1 Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
only to move the wire from pin 6 to pin 1 (yo must extract the pin 6 from the socket using a tiny screw driver) I done the small wire because the pin 1 is smallest (is like an adaptor) in this way you can return to the original configuration when you want..... ![]() ![]() IID Pro MV License |
CyberCharlie Member Since: 01 Jul 2010 Location: Reading Posts: 140 ![]() ![]() ![]() |
Just moving 1 wire does the trick?!? I have been waiting to recycle my AMR relay forever, hoping for such a solution.
Thanks DGardel!!! |
I've just done this mod - works perfectly with the 'old' intermittent wiper relay.
As Dgardel says, you only need to move the green / white wire from 6 to 1. Finding a tiny relay terminal can be hard - I 'unfurled' the existing terminal, narrowed it and 'refurled' it to fit in the smaller hole. Well done Dgardel! My blog - www.anacreinhampshire.blogspot.co.uk 110 TD5 BuildHERE - sold! 110 Tdci Build HERE - sold! Passat Alltrack - 4x4, auto, 45mpg, gloriously comfortable - but not a Defender! |
Yep, works great, takes 20 min to implement (i struggled removing the socket from position 6
![]() Thanks guys ![]() |
