Home > Puma (Tdci) > Intermitent Rear wiper
dgardel
Italy
Not mine Embarassed , taken from www.audax-team.de
VERY EASY MOD!!!!
Have you a standard/original Land Rover wiper ECU in your hand?
The green-white cable of position 6 of the base must be put on position 1
Test it..............................
..............job done Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #47086 2nd Dec 2010 3:51pm
nicks
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Alaska White
Is that red one, the one you replace with the VW 99 relay for variable front wipers?
Post #47120 2nd Dec 2010 7:28pm
dgardel
Italy
Yesss Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #47126 2nd Dec 2010 7:51pm
Zinke
United Kingdom 2003 Defender 90 Td5 HT Epsom Green
Very good!
Been wondering about that ever since i replaced my front relay, just havent had time to work out which wire goes where!
Just one question, do you need power to pin 1 and 6 or just power to pin 1?
Many thanks.
Pete.
Post #47170 2nd Dec 2010 10:19pm
SiWhite
United Kingdom 2013 Defender 110 Puma 2.4 USW Stornoway Grey
I'm doing this in the morning, if I can understand the instructions...
So the green and White wire comes out, then I get lost. Which wires are joined together? Is a new wire added anywhere? My blog - www.anacreinhampshire.blogspot.co.uk
110 TD5 BuildHERE - sold!
110 Tdci Build HERE - sold!
Passat Alltrack - 4x4, auto, 45mpg, gloriously comfortable - but not a Defender!
Post #47182 3rd Dec 2010 12:03am
dgardel
Italy
Zinke wrote:
Very good!
Many thanks.
Pete.
just to pin 1 Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #47184 3rd Dec 2010 12:31am
dgardel
Italy
only to move the wire from pin 6 to pin 1 (yo must extract the pin 6 from the socket using a tiny screw driver)
I done the small wire because the pin 1 is smallest (is like an adaptor)
in this way you can return to the original configuration when you want.....
Mr. Green Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #47185 3rd Dec 2010 12:31am
CyberCharlie
United Kingdom 2007 Defender 110 Puma 2.4 USW Java Black
Just moving 1 wire does the trick?!? I have been waiting to recycle my AMR relay forever, hoping for such a solution.
Thanks DGardel!!!
Post #47215 3rd Dec 2010 10:27am
SiWhite
I've just done this mod - works perfectly with the 'old' intermittent wiper relay.
As Dgardel says, you only need to move the green / white wire from 6 to 1.
Finding a tiny relay terminal can be hard - I 'unfurled' the existing terminal, narrowed it and 'refurled' it to fit in the smaller hole.
Well done Dgardel! My blog - www.anacreinhampshire.blogspot.co.uk
Post #47253 3rd Dec 2010 1:51pm
CyberCharlie
Yep, works great, takes 20 min to implement (i struggled removing the socket from position 6 Embarassed ) but... i am not 100% convinced... i mean: there might be situations when the contonous wipe is needed, for example when i want to "wash" the glass with the sprinklers. Has someone found a way to make the intermittent behave just like it used to do at the front (i am recycling the AMR relay)? I'd like it to wipe continously for 4 times and then stop when i press the sprinkler switch. Can it be done? i assume yes, and it is probably all about taking a feed from the positive that powers the pump and send somewhere in the relay. But where?
Thanks guys Smile
Post #48270 12th Dec 2010 2:06pm
