![]() | Home > Td5 > TD5 C-Cat |
Tank Member Since: 25 Jul 2014 Location: Fife Posts: 431 ![]() ![]() ![]() |
Does anyone know if the C-Cat is still made for the TD5 ?
153 views and no replies
What's a c cat?
![]() My build thread http://www.defender2.net/forum/topic17615.html |
if you referring exhaust Cat ![]() |
Looks exactly what it is......fake!
![]() Click image to enlarge ![]() Click image to enlarge You could consider making/designing your own? The one below is fitted on a Puma in exactly the same position as a TD5. ![]() Click image to enlarge ![]() Click image to enlarge If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
Do what I did, open it up and take out the honeycomb and weld it back up. It can't look anymore genuine than that
Thanks
achuakh Member Since: 12 Apr 2012 Location: Singapore Posts: 161 ![]() ![]() ![]() |
Remove it, smash the honeycomb inside with a pry bar and it's done, don't need to cut it open.
Well unless you intend to get some money from selling the cat innards (which is quite valuable) then cut it open and remove it and patch it back. The defender has migrated, leaving the owner behind. |
You have to cut the Td5 one open as there's no way you'll get a bar of any sort down the pipe, it's too far away from the ends.
Mike_B Member Since: 23 Jan 2011 Location: Moray Posts: 550 ![]() ![]() ![]() |
Gerbil armed with a file? That could work...
Clive Member Since: 21 Mar 2014 Location: Littleborough Posts: 467 ![]() ![]() ![]() |
I managed to get most of the innards out of mine (Td5) with a drain rod and one of the "cork screw" type ends on it, just flexible enough to get through the bends from the centre box end, couldn't get it all out but enough to make a difference.
i removed the entire down pipe and chassis cross member for the gear box to come down, so it was one of those, well, since it's accessible, lets take it out and smash the stuck animal inside it. The defender has migrated, leaving the owner behind.
