Home > Td5 > TD5 C-Cat
Tank
Scotland 2004 Defender 90 Td5 HT Zermatt Silver
TD5 C-Cat
Does anyone know if the C-Cat is still made for the TD5 ?
Post #481107 10th Dec 2015 7:34pm
Tank
153 views and no replies Smile
Post #482190 14th Dec 2015 7:32pm
mk1collector
What's a c cat? Big Cry Ray
My build thread
Post #482195 14th Dec 2015 7:48pm
Landy-Novice
c cat is a fake catalitic converter, a look alike/dummy to fool mot testers. alisport make 'um. Thumbs Up
Post #482202 14th Dec 2015 7:58pm
dorsetsmith
Re: TD5 C-Cat
if you referring exhaust Cat Question
Post #482203 14th Dec 2015 7:59pm
K9F
Looks exactly what it is......fake!
You could consider making/designing your own? The one below is fitted on a Puma in exactly the same position as a TD5.
 If you go through life with your head in the sand....all people will see is an ar5e!!
Post #482225 14th Dec 2015 8:42pm
JWL
Do what I did, open it up and take out the honeycomb and weld it back up. It can't look anymore genuine than that Thumbs Up
Post #482248 14th Dec 2015 9:40pm
Tank
Thanks Thumbs Up Thumbs Up Thumbs Up
Post #482286 14th Dec 2015 11:22pm
achuakh
Singapore 2002 Defender 90 Td5 SW Oslo Blue
Remove it, smash the honeycomb inside with a pry bar and it's done, don't need to cut it open.
Well unless you intend to get some money from selling the cat innards (which is quite valuable) then cut it open and remove it and patch it back. The defender has migrated, leaving the owner behind.
Post #482469 15th Dec 2015 4:05pm
JWL
You have to cut the Td5 one open as there's no way you'll get a bar of any sort down the pipe, it's too far away from the ends.
Post #482475 15th Dec 2015 4:19pm
Mike_B
United Kingdom 2006 Defender 110 Td5 USW Java Black
Gerbil armed with a file? That could work...
Post #482479 15th Dec 2015 4:39pm
Clive
United Kingdom 2004 Defender 90 Td5 X-Tech LE Zambezi Silver
I managed to get most of the innards out of mine (Td5) with a drain rod and one of the "cork screw" type ends on it, just flexible enough to get through the bends from the centre box end, couldn't get it all out but enough to make a difference.
Post #482480 15th Dec 2015 4:42pm
achuakh
i removed the entire down pipe and chassis cross member for the gear box to come down, so it was one of those, well, since it's accessible, lets take it out and smash the stuck animal inside it. The defender has migrated, leaving the owner behind.
Post #483033 17th Dec 2015 9:53am
