Page 869 of 1378 <123 ... 868869870 ... 137613771378>
alexatnd
Well, been a good day
Replaced crappy rear number plate light unit with LED version
Ascertained that the reversing light bulb contacts are shagged but power getting to connector and have ordered a NAS style Wipac LED equivalent
Replaced front windscreen washer unit. Some people said it was a b****r of a job, other said the top just came off and you push fit a replacement. This one broke when i tried to get the top off so ....
1). Remove ashtray from dashboard
2). Break off old unit and pull remaining bits back uip through ashtray
3). Fit 4.7 plastic tubing to replacement scoosher
4). Feed plastic tube through hole from outside
5). Feed washer and nut over plastic tube up to back of scoosher
6). Borrow wife with small hands to rotate nuyt onto threaded bit and hold it there with a scrtewdriver
7). turn scoosher round a few times until its tight against the bulkhead
Cool. Drive 28 miles to / back from Beverley to try and fine somwhere that's got a 4.7mm plastic hose joining thingy
9). Join old pipe to new pipe, job done simples!
Now got to do same with 'tother 110
At some point I'll remove dashboard and put in 2 scooshers one for each front seat, although why the passenger needs to see where I'm going is a mystery Smile) Santa - 1977 Series 3 - new chassis, tub, disc brakes,SU Carb
Gertie - 1999 110 TD5 - like a Phoenix from the ashes back on road... almost
Effie - 2004 110 TD5 County
Post #481804 13th Dec 2015 4:09pm
alexatnd
need to type slower Santa - 1977 Series 3 - new chassis, tub, disc brakes,SU Carb
Post #481805 13th Dec 2015 4:10pm
Had a look under the storage cover, it's still there are the batteries are good
Startech wheel still to be road tested but may happen sooner than expected
Post #481811 13th Dec 2015 4:35pm
Swac3
Fitted this:
Panel and power/USB ports from Mudstuff, Switches from Mobilecenter ( as they are switched the right way for my ocd)
Think I'll run in a better power and earth tho as I used the one off the old ciggy lighter for both.
Only one issue really and that's that the RWW amber bar lights as soon as i turn the ignition on, the wiper doesn't move unless I switch the switch to ON as expected, that said the 'park' feature has never worked, hmm
Gary 3 Landrovers
Post #481820 13th Dec 2015 5:15pm
PCA42
England 2008 Defender 110 Puma 2.4 DCPU Tonga Green
Went for a run up the A5 through Betws-y-Coed, and across to Anglesey to Red Wharf Bay to visit the birth place of the Land Rover... Something I wanted to get done this year.
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Pete
2010 Discovery 4 GS TDV6
1972 Series III 88" 2.25P
Post #481934 13th Dec 2015 11:01pm
excossack
Stopped at the roundabout on way home from work and bump! some hit me from behind. A lad in a VW Golf.
Damage report LR 0 - Golf 2 (Dent on the bumper and a bit of trim that almost fell off)
Didn't bother swapping details but I do have his number plate. No damage to mine as he hit the tow bar. 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #482229 14th Dec 2015 8:46pm
Venomator
Whoopsies, sorry to hear that John, hope there are no repercussions though... Shocked
Actually got to drive the Special to Cambridge today, at least to the Park & Ride to take the bus direct to Addenbrookes for the best part of the day... Thumbs Up
Left me radioactive for the day though... Mr. Green
 Rog... Mr. Green
The GREEN One...
MY2016 Urban Truck Build Thread - http://www.defender2.net/forum/topic40548....al[/color]
Post #482240 14th Dec 2015 9:13pm
excossack
I don't think there will be, the driver offered (and backs up what I spotted as well) information that would drop himself in some trouble.
I am happy the car is OK. Certainly no damage done - other than a scuffed tow ball cap. Maybe he will be more careful next time.
Told him to be more careful as well. 1999 Defender TD5 110
Regards
John M0VAZ
Post #482244 14th Dec 2015 9:29pm
JWL
Got another 12 months MoT on mine this morning, allways a relief even when you know it should go through with no hassle. Spotted another members 110 from on here waiting outside for a couple of little jobs Thumbs Up
Post #482718 16th Dec 2015 12:40pm
keith
Took a small 10hr drive down to Wales .
Met up with forum member and brought back 5 of these lovelies.
Many thanks John Thumbs Up see you in the highlands in the new year.
Post #482907 16th Dec 2015 7:53pm
ericvv
Tested in the dark the light production of my re-installed original SVX Wipac Cristal halogens with the VPLDV0061 H4 bulbs and the Landreiziger loom which directs the full 13.7/14.00V alternator power to the lights without any losses. Happy I took the EVOs back off (even if they were excellent) after running them for several years, the halogens as installed on mine are more than good enough. And, I do like the more classic looks of them more than the high tech looks of the Speakers. Happy that against the tide I went back to the future. Will not easily revert back to LEDs I think Laughing
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #482924 16th Dec 2015 8:34pm
@keith, they are sweet, especially at that price. Cool
Post #482929 16th Dec 2015 8:50pm
Wild Card 90
England 2012 Defender 90 Puma 2.2 SW Indus Silver
Eric
Eric,
having recently fitted Evo IIīs replacing Wipac Crystals and Nightbreaker H4īs, I can fully understand your decision. The LEDīs are good, and modern looking, but the classic look of the clear lenses does suit the Defender so well. Iīm keeping my Crystals boxed for a future date. The Halogens do offer a smoother cast of light, if not as intense as the LEDīs. 1998 Tdi 90 SW,
2008 Td4 90 SW,
2012 2.2 90 SW,
2" raised Trailmaster/Terrafirma
Heavy Track Raids, 255 MTīs,
Recaro CSīs, anorak, wellingtons
Post #483020 17th Dec 2015 8:58am
ericvv
Wild Card, what I like additionally is that the SVX front lights set up includes the 90mm halogen additional high beam driving lights. And in spite of multiple requests several years ago by me and other members here for one or more LED manufacturers (Speaker, Nolden) to produce a plug and play LED alternative for these 90mm lamps, nothing ever happened. I never liked having the main lamps as LED plus the aux high beam driving lamps as halogen. So now my front is fully halogen again, including the fogs. And frankly, the SVX double driving high beam lamps is giving me more than light enough for night driving.
Post #483027 17th Dec 2015 9:24am
A quick ten minute upgrade, done on my lunchtime...
Fitted a Mud interior light, really simple and the red is a nice touch..along with my maplights that can be adjusted to red (also from Mud) I can go into full 'hooker' mode Cool
Post #483089 17th Dec 2015 1:09pm
