Home > Maintenance & Modifications > Mud TD5 Facia plate, |
jonny2tanx Member Since: 06 Jul 2014 Location: Harpenden, Herts Posts: 156 |
Click image to enlarge Click image to enlarge I cant measure it as I have sold the car, but this may help? |
6th Dec 2015 5:03pm |
Swac3 Member Since: 21 Feb 2015 Location: Aberdeen Posts: 363 |
Actually YES, thanks
Hadn't thought about it until I looked at your pics but the DIN slot is of course a standard size ! Time to load a pic into photoshop and do some measuring, dimensions will be close enough for what i'm thinking. Cheers 3 Landrovers |
6th Dec 2015 8:46pm |
couplands Member Since: 31 Aug 2011 Location: Peak District & Cornwall Posts: 1826 |
Their website has this photo....any use...?
Cheers Simon |
6th Dec 2015 9:17pm |
You're welcome. I'm sure you already have done, but bear in mind there is a surround on the radio so its actually a bit wider than the din slot. I thought if you have the TD5 centre console you may be able to measure against that. Good luck with your project |
6th Dec 2015 9:26pm |
Had dismissed the actual console as it not exactly what i want, so going to fab something custom using the plate for the factory console, but thanks Simon. 3 Landrovers |
6th Dec 2015 11:54pm |
That's the thing I don't have the Genuine TD5 console or the MUD one.
Likely just buy the plate and see, or make something up from scratch I guess, it can't be worse than the sheet of chequer plate that someone installed there. 3 Landrovers |
7th Dec 2015 12:53am |
