Home > Maintenance & Modifications > Mud TD5 Facia plate,
Swac3
Hiya, Has anyone fitted one of these ?
I'm looking for the dimensions of the actual plate, intention to use one differently
but as Mud is closed till monday was hoping someone may have one installed and
could maybe take some rough measurements of the width and height of the plate.
Gary 3 Landrovers
Post #479634 6th Dec 2015 3:33pm
jonny2tanx
United Kingdom 2005 Defender 110 Td5 XS CSW Alveston Red
I cant measure it as I have sold the car, but this may help?
Post #479685 6th Dec 2015 6:03pm
Swac3
Actually YES, thanks
Hadn't thought about it until I looked at your pics but the DIN slot is of course a standard size !
Time to load a pic into photoshop and do some measuring, dimensions will be close enough for
what i'm thinking.
Cheers 3 Landrovers
Post #479795 6th Dec 2015 9:46pm
couplands
United Kingdom 2001 Defender 90 Td5 HT Oslo Blue
Their website has this photo....any use...?
Simon
Post #479803 6th Dec 2015 10:17pm
jonny2tanx
what i'm thinking.
You're welcome. I'm sure you already have done, but bear in mind there is a surround on the radio so its actually a bit wider than the din slot. I thought if you have the TD5 centre console you may be able to measure against that. Good luck with your project
Post #479808 6th Dec 2015 10:26pm
Swac3
Simon
Had dismissed the actual console as it not exactly what i want, so going to fab something custom
using the plate for the factory console, but thanks Simon. 3 Landrovers
Post #479854 7th Dec 2015 12:54am
Swac3
That's the thing I don't have the Genuine TD5 console or the MUD one.
Likely just buy the plate and see, or make something up from scratch I guess, it
can't be worse than the sheet of chequer plate that someone installed there. 3 Landrovers
Post #479858 7th Dec 2015 1:53am
