Home > Puma (Tdci) > Help please with EGR |
Cheshire110 Member Since: 26 Jul 2013 Location: Cheshire/London Posts: 2754 |
Hi Folks,
i have exhaust gases in my coolant causing my overheating issue. This is confirmed. I have no other head gasket symptoms. As such i suspect, or would at least like to rule out, a leak in the EGR cooler. (where exhaust gases and coolant could therefore mix) The car is remapped to disable the EGR and it has a blank fitted. I have drawn the following diagram to explain my question... Would a blank at Y be possible to keep exhaust gases out of contact with the coolant? Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Cheers, David Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
6th Dec 2015 3:17pm |
if you think you have leck in your EGR blank at Y and also bypass egr on the coolant side too
6th Dec 2015 3:32pm |
yep was just thinking that too. I couldn't quite see the hoses for the coolant. Is it possible to join them together? Cheers, David
6th Dec 2015 3:36pm |
if your EGR cooler look like this one YES
coolant pipes in top and bottom |
6th Dec 2015 3:50pm |
thanks, really appreciate your help.
I can't really tell if mine looks like this as its crammed behind the engine but if that is the standard 2.4 one than id imagine it would be? certainly looks like how i imagine it would look judging from what i can see at the exhaust manifold end Cheers, David Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
6th Dec 2015 3:53pm |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6298 |
yes.
mine is blanked at point 'Y'. I'm thinking however it's unlikely to be within the cooler - but what do I know? good luck. |
6th Dec 2015 4:03pm |
Thanks Caterham, will blank mine at Y anyway. This is where other cars are blanked anyway.
yep I've just got to the point where I want to rule it out fully, and it shouldn't be too hard a job to do. Cheers, David Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
6th Dec 2015 4:06pm |
Not at any worrying rate. Only a little by overpressurising and losing it out the cap. Cheers, David
6th Dec 2015 6:19pm |
big steve Member Since: 24 Dec 2009 Location: hertfordshire Posts: 2456 |
Very common personally blank y and bypass cooler with hoses
As water getting into the engine in other cases has caused to hydraulic Steve 2015 2.2 tdci hardtop xs 3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P hybrid turbo in build -done ready to fit ashcroft atb in transfer box 6 speed auto in build |
6th Dec 2015 6:43pm |
Thanks Steve 👍 Cheers, David
6th Dec 2015 7:39pm |
What would I need to connect the hoses together? Cheers, David
6th Dec 2015 7:40pm |
6th Dec 2015 8:04pm |
Perfect thanks! I could picture these but had no idea what they were called or how to find them! Cheers, David
6th Dec 2015 8:13pm |
shaggydog Member Since: 12 Aug 2012 Location: Kent Posts: 3347 |
I used them on my webasto install.
Very good bit of kit for not much money, just remember to put the jubilee clips on before you connect as once it is past one barb you wont get the apart again! Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197 Self confessed mileage hunter |
