Home > Maintenance & Modifications > footwell leaks - bulkhead is OK dealership claims
Page 2 of 3 <123>
Giby_off
Bulgaria 2012 Defender 110 Puma 2.2 SVX Station Wagon Havana
There were 3 rainy days during which I did't drive the car (the pictures have been taken after that).
Because of this I thought the water could be coming from above and not from the engine compartment.
Thanks for the Ingress manual. I will re-read it.
Tomorrow will try to seal windscreen seal with permanently elastic sealer
Post #476647 27th Nov 2015 11:18am
Theater
Italy 2009 Defender 110 Puma 2.4 SW Galway Green
o4dn wrote:
Granted, it's for older models, but the design hasn't changed much since then! Rolling with laughter
The manual for Puma Defender is "Puma leak procedure "
https://www.defender2.net/gallery/albums/u...cedure.pdf Marco
Defender 110 "SW" SE Galway Green MY 2009
Ex Defender 90 "SW" S Santorini Black MY 2010
Post #476657 27th Nov 2015 11:52am
Giby_off
This doc is new to me.
Post #476672 27th Nov 2015 1:13pm
Mirrordad
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Corris Grey
Mine had a leak with the water ending up in exactly the same place. I thought it was coming in between the bulkhead and the windscreen because that was where it was dripping from. The dealer "sealed" it but it still leaked so I took it back in. It turned out that it was leaking around the roof line and the water running down the A pillar behind the plastic trim and dripping into the footwell.
Post #477049 28th Nov 2015 5:02pm
Giby_off
Tomorrow I will take out the plastic trim and will check if there is water.
Today I checked if there is water inside, under the window behind the dashboard (took pictures with mobile phone and tested with fingers) and I was not able to find out any water traces.
Isolation between bulkhead and the window was wet (a lot of water). Checked with torch from outside the sealant and I saw that in front of driver seat dealer missed to cover with sealant the whole seal. Because of this I decided not to touch anything and called the dealer and Monday morning will take the car there. This time I will insist the to change the seal and not only to put sealant (windows silicone) on it.
Bulkhead-window seal looks like a sponge - how could it prevent the water going inside?
Post #477162 28th Nov 2015 8:39pm
Giby_off
Today I removed plastic trims which cover the window pillars. Tested Defender front window and the roof with 10 minutes heavy water jet but no water traces were found on the pillars.
Tomorrow gong to the dealer for 3rd time Smile
Post #477424 29th Nov 2015 7:11pm
Theater
Wink Marco
Post #477451 29th Nov 2015 8:25pm
Giby_off
I say new because I in that point in time I knew only the old Ingress manual.
Now I know it by heart Rolling with laughter
Post #477668 30th Nov 2015 3:34pm
Giby_off
Took it to the dealer. This time they took it very seriously and they decided to take out the dashboard and to investigate what is the reason for the leak. Since the car has 3+2 years warranty this approach will be much more expensive to me but I hope we will be able to solve the problem once for all.
Hahah this leads me to an IT joke Smile
"We have a problem."
"Remember, there are no such things as problems, only opportunities."
"Well then, we have a DDoS opportunity"
Post #477670 30th Nov 2015 3:38pm
Giby_off
Tomorrow I am taking back my car from the dealer. According them the problems wasn't coming from windscreen seal or from the bulkhead seal but from the driver door. When I take the car I will put it under waterterflow in order to test it Wink
Post #478004 1st Dec 2015 4:59pm
Happyoldgit
This really is nothing new. Rest assured you are treading a path that has been very well worn by 1000's of Land Rover owners before you. Steve.
http://forums.lr4x4.com
Post #478026 1st Dec 2015 6:00pm
Giby_off
You mean I will go 4th time to the dealer Laughing
I thought 3 trips to dealer are average and I will be within this number Rolling with laughter
Post #478093 1st Dec 2015 8:27pm
Giby_off
I took my car today. They told me that partially removed the dashboard and looked behind it while they were punting water on the car and according to them the water was coming from the drivers door. They sealed both front doors and the taps for RHD wipes.
Does someone knows how difficult is to exchange the bulkhead sealant? Can exchange it after you remove front hinges or you shall do something else as well?
Post #478359 2nd Dec 2015 4:05pm
Happyoldgit
If you mean the closed cell foam seal between the windscreen frame and top of the bulkhead then the usual way is to raise the roof which in turn allows the screen frame to be lifted for access to the seal. Most will just run a bead of sealant along the join with everything still in place.
Again this is nothing new and has been discussed here many times before. Steve.
Post #478363 2nd Dec 2015 4:14pm
Giby_off
Agree, nothing new just new actors. As you mentioned, there is also a new bed of sealant along the foam seal.
Post #478455 2nd Dec 2015 8:00pm
Page 2 of 3 <123>
