Home > Maintenance & Modifications > Front lights without clutter |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3639 |
Brendan thanks I may buy another bumper and move 2 of my lights towards the ends rather than the middle then DEFENDER 90 TDCI XS,
28th Nov 2015 9:00pm |
Ahmed Member Since: 16 Mar 2015 Location: Bahrain Posts: 13 |
This is what i did ..
29th Nov 2015 8:22am |
Lambley Member Since: 20 Apr 2013 Location: Mid Devon Posts: 1435 |
Hi LR90XS2011
When do you light come on? I've do they come on with full beam, headlights or are they set up a DLR's? Ideally I'm after something that comes on with full beam only just to give a brighter light, or as spot/fogs on a separate switch on the dash Cheers Ahmed, that front end looks great, I wish I had more £££'s |
29th Nov 2015 10:09am |
This provides a flexible lighting option, fogs, low/high with spots and a light bar for the really dark bits
Click image to enlarge |
29th Nov 2015 10:22am |
MuddyChris300tdi Member Since: 02 Mar 2014 Location: Derby Posts: 224 |
I fitted these to my Disco. Ok there won't be as bright as the lenzer but for £40 each they add more than enough light.
Click image to enlarge But any (flood) light won't be any good in fog as they light everything up. Maybe better to have floods on top of the bumper to come on with main beam and then some fogs under the bumper on a separate switch. |
29th Nov 2015 2:29pm |
I didn't get time to call Devon4x4 today but I'm wondering about altering a bumper, either my std one or a new one from devon4x4, cutting / drilling some holes to fit some lights into the bumper, these look about the right size, they could be mounted either on the front side or inside of the bumper for £25 and are small enough to fit...
http://www.ebay.co.uk/itm/401031235439?_tr...EBIDX%3AIT Or round ones, or just buy one from Bolton Bits.... http://www.ebay.co.uk/itm/391247644740?_tr...EBIDX%3AIT |
30th Nov 2015 5:55pm |
Hairysteve Member Since: 15 Jun 2015 Location: Surrey Posts: 692 |
Click image to enlarge Like this? |
30th Nov 2015 7:35pm |
Yep, just like that. What are they? Are they wired as spots or drl's Steve?
30th Nov 2015 7:45pm |
These are wired as DRL's but would easily have spots if wanted.
Come from here https://www.mobilecentre.co.uk/index.php?m...cts_id=543 Cheers Steve |
30th Nov 2015 7:52pm |
Merlin Member Since: 30 Oct 2010 Location: Newmarket Posts: 981 |
To keep the front really simple, just use the side lights as side/DRLs by incorporating a 5/21w light (LEDs are perfect). This is just a rear stop/tail mounted on the front with a clear lens. That's my solution and it's legal, simple and cheap.
Merlin |
1st Dec 2015 9:45pm |
m33ufo Member Since: 19 Jan 2008 Location: Cardiff Posts: 1150 |
I like that a lot. |
1st Dec 2015 9:55pm |
leeds Member Since: 28 Dec 2009 Location: West Yorkshire Posts: 8580 |
Sorry Merlin, but I am not sure that I fully understand what you mean.
For a start all vehicle obligatory lights have to be type approved or E marked. Now all legal lights have a code on them which designates what they are used for. A front side light or position light is marked A on the lens A rear position light is marked R and a brake light is S1 whereas the third/high level brake light is marked S3. I would question the legality of using a lamp designed as a rear stop/tail light on the front of a vehicle even if it had the correct coloured light fitted to it. Now taking a 5/21 watt filament light bulb out of a light unit and fitting a LED device in its place is illegal. The reason being that in the homologation of the light it should be specified what type of bulbs can be used. I have checked with two major European light manufacturers and they stated that replacing any filament bulb with a LED would invalidate their E marked approval If I have misunderstood what you have proposed then I apologise. Brendan |
1st Dec 2015 10:19pm |
PCA42 Member Since: 15 Jun 2014 Location: Church Stretton Posts: 468 |
Standard Chinese LED flood/driving lights mounted directly onto the top of the front bumper. I'd love Lazers, but can't justify the cost atm. They work well for what they are, fill the void between the front of the truck and the main beam, plus light up either side nicely. Wired in using the genuine LR auxiliary lamp harness kit, with toggle '2' switch on the dash.
Click image to enlarge Pete 2010 Discovery 4 GS TDV6 1972 Series III 88" 2.25P |
1st Dec 2015 11:59pm |
[quote="Lambley"]Hi LR90XS2011
When do you light come on? I've do they come on with full beam, headlights or are they set up a DLR's? Ideally I'm after something that comes on with full beam only just to give a brighter light, or as spot/fogs on a separate switch on the dash Cheers Hi Lambley mine are switched via a genuine LR auxiliary lighting kit and switch and can come on with the high beam when the auxiliary light switch is on or not if it is off, I therefore cant switch them on independently to the high beam. I currently have 2 off 55 watt bulbs and 2 off 35w bulbs fitted, and the LR components seam happy with this. Some peps on here suggested that having the lights this low creates shadows, but for road use I have never noticed this I have set them so 2 light up the verges and 2 the distance. I also have uprated headlight bulbs and the uprated loom with relays so my headlights are very bright but these lights still make a very noticable difference especially around the fringes of the headlight. Aesthetically I think if I did it again I would fit them below the headlamps but the rear of the bumper picks up loads of water and mud from the front wheels, in this position they stay pretty dry except when fording. I have had to seal the rears of the ring lights with silicone to stop water getting in but this only happened when I have been through a ford. My finishing rings came from Nakatenanga but you dont need them if you are neat with your tank cutter, I could have just repainted the cut edge on mine as the bumper drilled out very neatly. One thing I have noticed is this mod is always commented on favourably by other LR owners when they look at my car. DEFENDER 90 TDCI XS, I hope everyone is well and your land rovers make you happy |
2nd Dec 2015 6:38am |
