Home > Puma (Tdci) > RedeX
Page 2 of 2 <12
Happyoldgit
IIRC the dealers have stuck some Forte in mine at service time. Steve.
http://forums.lr4x4.com
Post #47575 6th Dec 2010 1:51pm
K9F
fekete wrote:
put millers diesel additive in it every tank and change your oil every 6k Thumbs Up
Exactly what I do! Each to their own...What suits some may not suit others! Suits me!!!! Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #47581 6th Dec 2010 2:29pm
dgardel
Italy
Re: RedeX
Defendit wrote:
Caterham wrote:
any thoughts.....
Yes, use 2 stroke instead. Wink
http://www.freel2.com/forum/topic878.html? will give you the basics, but read it from the start and then do some other searching of the net. Thumbs Up
Yes it is the best additive for our engine.................. Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #47585 6th Dec 2010 2:49pm
stevie d
United Kingdom 2003 Defender 90 Td5 SW Alpine White
Eutek,
From reading around the subject all the money seems to be on changing oil at circa 6k, rather then going the distance. I guess it will make no difference for the first 100k, but....... if you want to pull 200 to 300k out of the engine, regular oil changes are the only way forward.
Steve Thumbs Up Defender 90 TD5 Station Wagon
Discovery 3 HSE
BMW 330i Coupe
Post #47594 6th Dec 2010 4:24pm
stevie d
This this the article I couldn't find last night from the Oilman web site.
It certainly put me off adding anything to my engine/gearboxes/axles Whistle
http://www.opieoils.co.uk/pdfs/tech-articl...itives.pdf Defender 90 TD5 Station Wagon
Discovery 3 HSE
BMW 330i Coupe
Post #47595 6th Dec 2010 4:29pm
spudfan
Ireland
Would Castrol Actevo 2T spec JASO FC,API TC, ISO L-EGC be suitable to mix with the diesel?. Have been thinking of trying this but have been looking for the correct 2 stroke. 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #47782 7th Dec 2010 11:04pm
johnnyturbo2002
Spain 2008 Defender 110 Puma 2.4 CSW Java Black
stevie d wrote:
Have a look at this.
http://www.carbibles.com/additives.html
after growing up in the states and leaving some 5 years ago, ( I'm almost 40!) The tele always had on the commericials of these guys trying to sell their oils, I must admit, it was pretty convincing most of the time.
Thanks for the link.
I enjoy the part where he says,
"Having said that, if you start the engine and let it idle for 15 seconds or so before moving off, you can probably add another 100,000 miles to your engine's life without one bottle of additive. This warms the oil up a tad and makes sure it's in all the most vital areas before you start putting a strain on the engine."
Does this mean that if I let my car idle for 5 minutes I can get (15x4)=60x100000miles=6000000 milesx5=30000000? probably not, but it would be pretty cool huh?
Read more: http://www.carbibles.com/additives.html#ixzz17UwicK1F 2008 Defender 110 60 year Edition (sold unfortunately)
IN the hunt for another Puma for the wifey!
2008 Kia Sorento LX 😁 2.5crdi
Post #47790 8th Dec 2010 6:18am
Naks
Yep, JASO-FB or FC are fine, but DONT use synthetic 2-stroke!
As a rule of thumb, one should always idle any engine for 30s or so, and then drive at a leisurely pace (not revving too hard) until the engine is at operating temperature. Thumbs Up
Post #47792 8th Dec 2010 7:17am
mse
I got into a debate with a few other people on that very issue...leave your car to idle for a few seconds in the cold or drive off/accelerate straight away.
The leave for a few seconds was to get things running around the engine etc
The drive off straight away was to push oil around the engine via the pump quicker.
For each of those there seems to be a supporter... Mike
Post #47797 8th Dec 2010 8:01am
spudfan
Ireland
Finally got around to putting the 2 stroke oil into the diesel of the Puma. Must ask the wife how she is getting on! Laughing 1982 88" 2.25 diesel
Post #48001 9th Dec 2010 7:16pm
Grockle
I put Fortron diesel additive in our Puma once a month 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #48089 10th Dec 2010 10:52am
Page 2 of 2 <12
