Home > Puma (Tdci) > RedeX |
Happyoldgit Member Since: 14 Sep 2007 Location: Norfolk Posts: 3471 |
IIRC the dealers have stuck some Forte in mine at service time. Steve.
6th Dec 2010 1:51pm |
Exactly what I do! Each to their own...What suits some may not suit others! Suits me!!!! If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
6th Dec 2010 2:29pm |
Yes it is the best additive for our engine.................. Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
6th Dec 2010 2:49pm |
stevie d Member Since: 09 Nov 2009 Location: Bishops Stortford Posts: 342 |
Eutek,
From reading around the subject all the money seems to be on changing oil at circa 6k, rather then going the distance. I guess it will make no difference for the first 100k, but....... if you want to pull 200 to 300k out of the engine, regular oil changes are the only way forward. Steve Defender 90 TD5 Station Wagon Discovery 3 HSE BMW 330i Coupe |
6th Dec 2010 4:24pm |
This this the article I couldn't find last night from the Oilman web site.
It certainly put me off adding anything to my engine/gearboxes/axles http://www.opieoils.co.uk/pdfs/tech-articl...itives.pdf Defender 90 TD5 Station Wagon Discovery 3 HSE BMW 330i Coupe |
6th Dec 2010 4:29pm |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4731 |
Would Castrol Actevo 2T spec JASO FC,API TC, ISO L-EGC be suitable to mix with the diesel?. Have been thinking of trying this but have been looking for the correct 2 stroke. 1982 88" 2.25 diesel
7th Dec 2010 11:04pm |
johnnyturbo2002 Member Since: 21 May 2009 Location: Poniente Granadino Posts: 371 |
after growing up in the states and leaving some 5 years ago, ( I'm almost 40!) The tele always had on the commericials of these guys trying to sell their oils, I must admit, it was pretty convincing most of the time. Thanks for the link. I enjoy the part where he says, "Having said that, if you start the engine and let it idle for 15 seconds or so before moving off, you can probably add another 100,000 miles to your engine's life without one bottle of additive. This warms the oil up a tad and makes sure it's in all the most vital areas before you start putting a strain on the engine." Does this mean that if I let my car idle for 5 minutes I can get (15x4)=60x100000miles=6000000 milesx5=30000000? probably not, but it would be pretty cool huh? Read more: http://www.carbibles.com/additives.html#ixzz17UwicK1F 2008 Defender 110 60 year Edition (sold unfortunately) IN the hunt for another Puma for the wifey! 2008 Kia Sorento LX 😁 2.5crdi |
8th Dec 2010 6:18am |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2651 |
Yep, JASO-FB or FC are fine, but DONT use synthetic 2-stroke!
As a rule of thumb, one should always idle any engine for 30s or so, and then drive at a leisurely pace (not revving too hard) until the engine is at operating temperature. |
8th Dec 2010 7:17am |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5054 |
I got into a debate with a few other people on that very issue...leave your car to idle for a few seconds in the cold or drive off/accelerate straight away. The leave for a few seconds was to get things running around the engine etc The drive off straight away was to push oil around the engine via the pump quicker. For each of those there seems to be a supporter... Mike |
8th Dec 2010 8:01am |
Finally got around to putting the 2 stroke oil into the diesel of the Puma. Must ask the wife how she is getting on! 1982 88" 2.25 diesel
9th Dec 2010 7:16pm |
