![]() | Home > Puma (Tdci) > The Caterham Scale of Frustration |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6318 ![]() ![]() ![]() |
Nooooooo!
I've eve got some leather on the way and a service (oil n filter change) this weekend |
Dunno Wayne, I tend just to get in and drive mine in the same manner as any other vehicle - as part of daily life - I've enough to worry about elsewhere without looking upon Defender noises and quirks as a source of over analysis and endless conjecture. Steve. Owned numerous Land Rover vehicles of all shapes and sizes over the decades. Current Defender: A non tarts hand-bagged Puma 110 XS USW. [Insert something impressive here such as extensive list of previous Land Rovers or examples of your prestigeous and expensive items, trinkets, houses, bikes, vehicles etc] http://forums.lr4x4.com I used to be Miserable ...but now I'm ecstatic. |
andyc Member Since: 15 Jul 2015 Location: Cheshire Posts: 44 ![]() ![]() |
Slightly off topic - I sold my Caterham and really miss it...!
Wish we could sell 'ours' sometimes. Doubt if we'll miss him nearly as much?
Suppose we will after a while? ![]() Treat every day as if it is your last....one day you will be right!! |
gilarion Member Since: 05 Dec 2013 Location: Wales Posts: 5115 ![]() ![]() ![]() |
I would miss Caterham, if only for the reason that after reading his many problems he makes me feel delighted that I do not suffer from his many Defender related problems.
![]() http://www.youtube.com/user/conwy1 |
![]() so if it is now sorted (other than perhaps the restrictor valve on the clutch - strangely the clutch has gone smooth in the cold weather and other than the drivers door locking solenoid struggling) it's taken just over 5 years ![]() ![]() |
enfield_dinosaur Member Since: 14 Jun 2015 Location: Tertius orbis Posts: 120 ![]() ![]() |
The injector is fixed! Really? And the culprit is the fuel filter?
I'm thinking there was nothing wrong with the injectors. the noise I was getting was like the sound of heavy injector knock. fitting the fuel filter properly APPEARS to have cured the problem - I'm assuming it was letting air in?
I can't say for sure but something you all might want to double check? |
ian series 1 Member Since: 17 Nov 2014 Location: south Posts: 3127 ![]() ![]() ![]() |
I am intrigued as to how "you badly fit a fuel filter"?
It's either on or off! ![]() Wanted, Forward Control Anything considered. |
I'm having mine at the garage currently for servicing. The fuel filter is part of the service - I'll listen closely...
I couldn't hear a 'click' as is suggested on the side of the fuel can. what I intend to do is mark the can and 'measure' what is fully on to off.
I suggest it's quite vague to determine what is and isn't fully fitted (unless for some reason mine was just a poor fit - but doubt it)? |
Well, I'm glad to hear that the "Caterham Scale of Frustration" currently seems to have abated to very low levels, and you get more satisfaction from your vehicle.
The scale itself is something I use to measure my own frustrations ![]() But I'm currently pretty happy with it. |
![]() I hope the CSoF is also registering low for yourself presently? ![]() |
Are you sure the position of the sunvisors are not having an effect on all the problems over the years? I mean have you noticed any correlation between visor up and visor down and number of issues you perceive exist? After all they are connected to the vehicle as are all the other mysterious semi problem and defective components, maybe having the visors up / down / midway stresses the feng shui balance of the whole machine? Steve.
