Home > Puma (Tdci) > The Caterham Scale of Frustration
Page 6 of 8 <12345678>
Caterham
ian series 1 wrote:
Rolling with laughter Rolling with laughter Rolling with laughter
Shocked glad you find it funny!
with a family and full time job(s) it's a struggle to keep on top of the defender. especially now I have to take it in to have the roof sprayed for the second time in as many months......and yes corrosion of the roof is likely a result of me not cross bonding the cathodic protection onto the roof - foolish me (again). Sad
Post #476070 25th Nov 2015 2:11pm
Caterham
Wasn't too sure where to post this?
Please bear with me on this.
So i'll be the first to admit i've not painted in great picture of my mechanical skills but to be honest I do believe I have above average skills in that department (but a westfiled back in the 80's and even if I say so myself it was a mighty fine example and a caterham. Have been doing basic servicing and repairs ever since.
Anyhow back to the defender. Contrary to what you all think i'm 99% sure there's still an intermittent fault that's results in rough under powered performance and dreadful gear changes.
It seems to be linked to clutch pedal operation that is heavy and creaks? The clutches seems to be lighter and smoother when cold and seemingly the engine seems smoother when the clutch works better ie the engine seems smoother with less injector knock type noise when cold which to my mind is the opposite to what you would expect with a diesel? This isn't all the time but i'm pretty sure now there is a link with cold / clutch / engine running smoothly?
Due to get clutch master cylinder replaced soon but just can't see how this could the full fix? Any thoughts / suggestions very welcome.
Before you come back and suggest it's me pretty much everything else i've been concerned about has been fixed because there WAS a problem. Almost there with everything but this is proving a bum to find / resolve.
Post #484223 21st Dec 2015 6:27pm
mk1collector
Can't you give us a break, it's nearly Christmas Big Cry Ray
My build thread
Post #484326 22nd Dec 2015 12:18am
Caterham
aha Christmas. hopefully I'll have plenty of spare time to frequent D2.net Very Happy
speaking to Martin however there's an option for those who'd rather avoid my posts.......
'close your eyes' Thumbs Up
- any thoughts on my previous post?
once again this morning drove perfectly and clutch was smooth and no creaking.
Post #484357 22nd Dec 2015 8:57am
ickle
Hi Caterham
Just had the clutch replaced on mine and did the slave cylinder etc at the same time. As its done over 100k I also did the master at the same time, & for other reasons I replaced the pedal assembly with new take off parts, it made a big difference to operation.
I did note that it appears that water ingress into the pivot point is restricted by a snot of silicone that has been painted over each end - perhaps drilling a tiny hole into each of the bearings to allow some lube in may help?
As for rough running, I'm convinced its down to the quality of the diesel and there appears to be no good or bad suppliers.
Keith
Post #484364 22nd Dec 2015 9:41am
Caterham
Ickle,
thanks very much for your response. In terms of the diesel I'm inclined to think it has nothing to do with it in this instance as the smoothness of the engine could change numerous times from good to bad on the same tank full.
had the clutch, slave cylinder and extension shaft all replaced not so long back. waiting to get the master cylinder done. perhaps I need to look at getting the pedal assembly replaced. Thumbs Up
I'll see if I can find anything on here re the pedal assembly and how easy / difficult it is to replace - strange thing is though it comes and goes - generally it's at it's best / smoothest without creaks when cold - defineately worst when hot?
thanks again.
Post #484365 22nd Dec 2015 9:51am
VeeTee
Netherlands
^^^ there is thread here about installing a grease nipple in the pedal box. Cheers, Vincent
MySite
Post #484371 22nd Dec 2015 10:11am
ickle
Thanks VeeTee - I missed that one - also didn't see the drilling on the replacement.
Is there a point each side or is the shaft hollow and greases both bushes?
Cheers Keith
Post #484374 22nd Dec 2015 10:17am
VeeTee
Netherlands
Don't know, haven't don it myself yet because the weather has been a bit wet lately... Cheers, Vincent
MySite
Post #484393 22nd Dec 2015 10:51am
ickle
Well been outside for a looksie and as mine is a left hand drive I can only access the right hand side (looking forwards) of the pivot and although the shaft appears to be hollow, there is no internal thread on this side.
The left hand side is virtually inaccessible under the wing & if I somehow managed to fit a nipple, the chance of getting a grease gun on is non existent.
I do wonder though if there is a difference between the lhd & rhd pedal assemblies? The 'new' one only had 5 mounting nuts, the old unit had 6, although everything else looked identical & it works well.
Keith
Post #484445 22nd Dec 2015 1:20pm
Caterham
would I be right in thinking the pedal assembly can be taken out while leaving everything (master cylinder) in situ ie remove the nut(s) of the threaded actuator rod and the pedal should 'drop' down into the foot well?
I can then remove / refit the but etc and fit grease nipple etc.
Post #484465 22nd Dec 2015 2:19pm
ickle
No, disconnect the pipe from the master cylinder and the complete assembly lifts out through the engine bay.
Post #484530 22nd Dec 2015 5:57pm
Riccarton
Scotland 2012 Defender 90 Puma 2.2 HT Zambezi Silver
@ Caterham,
Please excuse my ignorance and I could be spouting complete tosh but.....
I noticed yours is an XS CSW (mine too basic for all this malarky I think) so could it have position monitoring on the clutch - i.e. does it detect when the clutch is depressed (possibly as part of HDC / ABS / etc)?
If so I wonder if you squeaking / griking clutch pedal goes hand in hand with something seizing and the monitoring system believing the clutch is disengaged which may in turn affect fuelling hence smoothness / performance?
On a D3 / D4 or such like it sounds completely feasible to a person of little brain like me but not sure a Defender would have such things.
Just thinking out loud Thumbs Up
Post #484540 22nd Dec 2015 6:25pm
jst
try it with the clutch switch off?
try lubricating the pivots/spring to get rid of the groan if its coming from the pedal
elongate the pedal to improve leverage it will then be lighter.
assembly as ^^ comes out through the engine bay.
how does it compare to others... Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #484545 22nd Dec 2015 6:36pm
Caterham
Hi. I think all the pumas have sensor on the clutch and yes it does link into the 'brain' / Ecm.
Aha. Not looked at it yet but thought / hoped the pedal would drop down into foot well not up thro engine bay.
The stiffness is either th pivo or the master cylinder (hopefully nothing else). Whether whatever is stiff is preventing the senor form seeing the clutch pedal being released and is keeping pressure in the system?
Don't know. Never noticed any slip on the clutch so doubt the above?
What's the chance of removing the clutch pedal and not needing to bleed system - not got anything for bleeding ie not sure what hoses / connections are req'd.
Thanks.
Post #484548 22nd Dec 2015 6:44pm
