Home > Puma (Tdci) > The Caterham Scale of Frustration |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6298 |
Nooooooo!
I've eve got some leather on the way and a service (oil n filter change) this weekend |
30th Oct 2015 6:45pm |
Happyoldgit Member Since: 14 Sep 2007 Location: Norfolk Posts: 3471 |
Dunno Wayne, I tend just to get in and drive mine in the same manner as any other vehicle - as part of daily life - I've enough to worry about elsewhere without looking upon Defender noises and quirks as a source of over analysis and endless conjecture. Steve. Owned numerous Land Rover vehicles of all shapes and sizes over the decades. Current Defender: A non tarts hand-bagged Puma 110 XS USW. [Insert something impressive here such as extensive list of previous Land Rovers or examples of your prestigeous and expensive items, trinkets, houses, bikes, vehicles etc] http://forums.lr4x4.com I used to be Miserable ...but now I'm ecstatic. |
31st Oct 2015 10:50am |
andyc Member Since: 15 Jul 2015 Location: Cheshire Posts: 44 |
Slightly off topic - I sold my Caterham and really miss it...!
20th Nov 2015 4:45pm |
Wish we could sell 'ours' sometimes. Doubt if we'll miss him nearly as much?
Suppose we will after a while? If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
20th Nov 2015 4:48pm |
gilarion Member Since: 05 Dec 2013 Location: Wales Posts: 5109 |
I would miss Caterham, if only for the reason that after reading his many problems he makes me feel delighted that I do not suffer from his many Defender related problems. For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
20th Nov 2015 5:23pm |
so if it is now sorted (other than perhaps the restrictor valve on the clutch - strangely the clutch has gone smooth in the cold weather and other than the drivers door locking solenoid struggling) it's taken just over 5 years ....on the plus side however my long standing issue over injector knocking sound and just recently when the weather turned what appeared to be glow plug issues all seems to be resolved now the fuel filter is properly fitted (ooops) |
24th Nov 2015 7:42am |
enfield_dinosaur Member Since: 14 Jun 2015 Location: Tertius orbis Posts: 120 |
The injector is fixed! Really? And the culprit is the fuel filter?
24th Nov 2015 11:16am |
I'm thinking there was nothing wrong with the injectors. the noise I was getting was like the sound of heavy injector knock. fitting the fuel filter properly APPEARS to have cured the problem - I'm assuming it was letting air in?
I can't say for sure but something you all might want to double check? |
24th Nov 2015 11:20am |
ian series 1 Member Since: 17 Nov 2014 Location: south Posts: 3127 |
I am intrigued as to how "you badly fit a fuel filter"?
It's either on or off! 80" 80" 86" 88" 90" Wanted, Forward Control Anything considered. |
24th Nov 2015 11:21am |
I'm having mine at the garage currently for servicing. The fuel filter is part of the service - I'll listen closely...
24th Nov 2015 11:23am |
I couldn't hear a 'click' as is suggested on the side of the fuel can. what I intend to do is mark the can and 'measure' what is fully on to off.
I suggest it's quite vague to determine what is and isn't fully fitted (unless for some reason mine was just a poor fit - but doubt it)? |
24th Nov 2015 11:26am |
Well, I'm glad to hear that the "Caterham Scale of Frustration" currently seems to have abated to very low levels, and you get more satisfaction from your vehicle.
The scale itself is something I use to measure my own frustrations But I'm currently pretty happy with it. |
24th Nov 2015 11:28am |
I hope the CSoF is also registering low for yourself presently? |
24th Nov 2015 1:19pm |
Are you sure the position of the sunvisors are not having an effect on all the problems over the years? I mean have you noticed any correlation between visor up and visor down and number of issues you perceive exist? After all they are connected to the vehicle as are all the other mysterious semi problem and defective components, maybe having the visors up / down / midway stresses the feng shui balance of the whole machine? Steve.
24th Nov 2015 2:46pm |
