Home > Technical > Handbrake sticking. Suggestions?
NoDo$h
Handbrake stuck on this morning. After 10 minutes rummaging around under the car I opted for plan b and just rocked back and forth in low range until it released.
Anyone got any suggestions on how best to adjust/grease/hit with ever-larger hammers to prevent this please? And yes, an x-brake will be on the shopping list, just not yet Thumbs Up
Cheers!
Al
54 Freelander modded for mud
2008 D3 SE
2010 90 XS SW
1978 88 Series 3 undergoing surgery with a new owner
2007 90 County Truck Cab - gone
2006 D3 SE - gone
2004 Freelander Sport - gay
1999 Disco V8 ES rotted to bits
Post #47551 6th Dec 2010 10:49am
jst
just leave it on when a freeze is due, its the same as the old drum brakes sticky. any moisture in there freezes over night and leaves it stuck on.
a tap with a lump hammer to the drum and/or back plate also works as does direct heat. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #47556 6th Dec 2010 11:09am
RED-DOT
I was always told to leave it off and park in 1st gear. If you park on snow or ice with ONLY the handbrake on all it will need is for one rear wheel to slip and you have a 2 Ton sledge. After submerging the handbrake drum in water or spray the shoes will rust to the cast iron drum in next to no time. 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Post #47557 6th Dec 2010 11:25am
jst
'ONLY the handbrake on all it will need is for one rear wheel to slip and you have a 2 Ton sledge. '
correct, if its left in gear though and no handbrake it still only needs one wheel to slip for it to be able to move.
in gear in diff lock in would be one wheel on the front and one on the rear axle to slip at the same time for it to move. (still no handbrake)
best practice is handbrake and in gear. in the cold weather i just leave mine in gear with no handbrake. i suppose really i should put it in difflock too but then its on a level drive anyway. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #47559 6th Dec 2010 11:39am
NoDo$h
Thanks for the prompt replies. So in essence the damn thing will either rust to the drum or freeze to it. Ok, leaving in gear and saving for an x-brake it is then Bow down
2008 D3 SE
2010 90 XS SW
2006 D3 SE - gone
Post #47565 6th Dec 2010 12:42pm
