![]() | Home > Technical > Handbrake sticking. Suggestions? |
NoDo$h Member Since: 18 Aug 2007 Location: Buried in deer guts in Dorset Posts: 972 ![]() ![]() |
Handbrake stuck on this morning. After 10 minutes rummaging around under the car I opted for plan b and just rocked back and forth in low range until it released.
Anyone got any suggestions on how best to adjust/grease/hit with ever-larger hammers to prevent this please? And yes, an x-brake will be on the shopping list, just not yet ![]() Cheers! Al ![]() 54 Freelander modded for mud 2008 D3 SE 2010 90 XS SW 1978 88 Series 3 undergoing surgery with a new owner 2007 90 County Truck Cab - gone 2006 D3 SE - gone 2004 Freelander Sport - gay 1999 Disco V8 ES rotted to bits |
RED-DOT Member Since: 29 Jun 2009 Location: stirling Posts: 2363 ![]() ![]() |
I was always told to leave it off and park in 1st gear. If you park on snow or ice with ONLY the handbrake on all it will need is for one rear wheel to slip and you have a 2 Ton sledge. After submerging the handbrake drum in water or spray the shoes will rust to the cast iron drum in next to no time. 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8229 ![]() ![]() ![]() |
'ONLY the handbrake on all it will need is for one rear wheel to slip and you have a 2 Ton sledge. '
correct, if its left in gear though and no handbrake it still only needs one wheel to slip for it to be able to move. in gear in diff lock in would be one wheel on the front and one on the rear axle to slip at the same time for it to move. (still no handbrake) best practice is handbrake and in gear. in the cold weather i just leave mine in gear with no handbrake. i suppose really i should put it in difflock too but then its on a level drive anyway. Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
Thanks for the prompt replies. So in essence the damn thing will either rust to the drum or freeze to it. Ok, leaving in gear and saving for an x-brake it is then
![]() ![]() 54 Freelander modded for mud 2008 D3 SE 2010 90 XS SW 1978 88 Series 3 undergoing surgery with a new owner 2007 90 County Truck Cab - gone 2006 D3 SE - gone 2004 Freelander Sport - gay 1999 Disco V8 ES rotted to bits |
