![]() | Home > Puma (Tdci) > Odd gremlins! |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17608 ![]() ![]() ![]() |
Not unusual. First check is that all the relays under the driver's seat are properly inserted and really secure. A loose connection on the main, ignition, or starter relay will do this.
The relays should be really tight in th sockets. |
100inch Member Since: 15 May 2012 Location: Brunswick Posts: 411 ![]() ![]() ![]() |
Hi blackwolf,
Thanks for getting back. Will give it a go:) m |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6641 ![]() ![]() ![]() |
That sounds like the engine ECU not powering up and providing the CAN bus data for the dashboard.
As above, check power and earth feeds to the ECU. ![]() ![]() |
yaho Member Since: 26 Nov 2008 Location: Bialystok Posts: 200 ![]() ![]() ![]() |
Do you have an ODB scanner connected? I had same symptoms after disconnecting battery and not going through scanner's start-up procedures. Janusz
www.yahodeville.com |
I will plug up and see what codes are listed. Guess earth and relays can do with a check as well:/
m |
