Home > Puma (Tdci) > Odd gremlins!
100inch
Australia 2010 Defender 110 Puma 2.4 CSW Santorini Black
Odd gremlins!
So my 2010 did something very odd today. Turning ignition on resulted in the temperature gauge going full up and no glow plug sign. I switched it on and off a few times and started. I experienced the glow plug not coming on in the past with the engine consequently not starting. Reading the codes showed no clues.... does anyone had the same happening? Cheers m
Post #475071 22nd Nov 2015 9:30am
Not unusual. First check is that all the relays under the driver's seat are properly inserted and really secure. A loose connection on the main, ignition, or starter relay will do this.
The relays should be really tight in th sockets.
Post #475157 22nd Nov 2015 3:23pm
100inch
Hi blackwolf,
Thanks for getting back. Will give it a go:) m
Post #475336 23rd Nov 2015 8:21am
Martin
Site Admin
That sounds like the engine ECU not powering up and providing the CAN bus data for the dashboard.
As above, check power and earth feeds to the ECU.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #475366 23rd Nov 2015 10:15am
yaho
Poland 2007 Defender 90 Puma 2.4 SW Keswick Green
Do you have an ODB scanner connected? I had same symptoms after disconnecting battery and not going through scanner's start-up procedures. Janusz
www.yahodeville.com
Post #475373 23rd Nov 2015 10:40am
100inch
I will plug up and see what codes are listed. Guess earth and relays can do with a check as well:/
m
Post #475717 24th Nov 2015 9:48am
