Home > Puma (Tdci) > Odd gremlins! |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17373 |
Not unusual. First check is that all the relays under the driver's seat are properly inserted and really secure. A loose connection on the main, ignition, or starter relay will do this.
The relays should be really tight in th sockets. |
22nd Nov 2015 3:23pm |
100inch Member Since: 15 May 2012 Location: Brunswick Posts: 411 |
Hi blackwolf,
Thanks for getting back. Will give it a go:) m |
23rd Nov 2015 8:21am |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6605 |
That sounds like the engine ECU not powering up and providing the CAN bus data for the dashboard.
As above, check power and earth feeds to the ECU. 1988 90 Td5 NAS soft top 2015 D90 XS SW |
23rd Nov 2015 10:15am |
yaho Member Since: 26 Nov 2008 Location: Bialystok Posts: 200 |
Do you have an ODB scanner connected? I had same symptoms after disconnecting battery and not going through scanner's start-up procedures. Janusz
www.yahodeville.com |
23rd Nov 2015 10:40am |
I will plug up and see what codes are listed. Guess earth and relays can do with a check as well:/
m |
24th Nov 2015 9:48am |
