Home > Td5 > Code reader suddenly can't read codes
4RF RDS
Canada 2000 Defender 110 Td5 XS CSW Epsom Green
My code reader suddenly tells me that the ECU's are not communicating with it. I had the ABS and TC light up this afternoon and went to read it almost right after it happened. My reader cannot get anything from the engine ECU or the ABS ECU. Shut off the engine removed key locked it up and did it all over again, still won't read. It has worked flawlessly prior to this reading live data and misc codes etc. I checked the reader with my Range Rover and it works fine.
Any ideas? Thanks 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam)
2000 Defender 110 CSW TD5 (CTX)
1992 Range Rover Classic (Lizzy)
1972 Series III 300 Tdi (Stanwood)
1967 MGB GT
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken (1880 - 1956)
Post #474756 20th Nov 2015 11:03pm
K9F
What reader is it? Does the reader power up when it's connected to the Defender? If you go through life with your head in the sand....all people will see is an ar5e!!
Post #474757 20th Nov 2015 11:06pm
4RF RDS
Yes it powers up and goes through its diagnostic. I can run it through autoscan and manual scan but both end up with the message of no connection. As I said it worked on the Defender just days ago... Both manula diagnostic and OBDII work on my Rangie. Its an iCarsoft 930 from Terrafrima. 2010 Range Rover MkIII Autobiography Super Charged (Idris)
1967 MGB GT
Post #474765 21st Nov 2015 2:52am
jasong4110
United Kingdom 2003 Defender 110 Td5 G4 LE Java Black
Td5 is not odb11 compliant as it uses a different (lower) baud rate, there are a few threads about your scanner not working with it and people returning them.
It will talk to the ABS ecu and will have read functions on the serial number but beyond that not much good.
Jason
Post #474766 21st Nov 2015 3:21am
4RF RDS
Thanks, it was working! It seems to have the ability to read both but right now it is not reading? 2010 Range Rover MkIII Autobiography Super Charged (Idris)
1967 MGB GT
Post #474811 21st Nov 2015 11:15am
roel
I have that with my Nanocom sometimes. just a restart works most off the time for me. Roel
2003 90 Td5 (2009-now)
Post #474865 21st Nov 2015 3:00pm
4RF RDS
Well went out this morning plugged it in and bam! No issues... Guess my ECUs just wanted a break from speaking. Smile. Thanks everyone. 2010 Range Rover MkIII Autobiography Super Charged (Idris)
1967 MGB GT
Post #474884 21st Nov 2015 3:56pm
