![]() | Home > Td5 > Code reader suddenly can't read codes |
What reader is it? Does the reader power up when it's connected to the Defender? If you go through life with your head in the sand....all people will see is an ar5e!!
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 937 ![]() ![]() ![]() |
Yes it powers up and goes through its diagnostic. I can run it through autoscan and manual scan but both end up with the message of no connection. As I said it worked on the Defender just days ago... Both manula diagnostic and OBDII work on my Rangie. Its an iCarsoft 930 from Terrafrima. 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
jasong4110 Member Since: 18 Oct 2009 Location: Henley On Thames Posts: 268 ![]() ![]() ![]() |
Td5 is not odb11 compliant as it uses a different (lower) baud rate, there are a few threads about your scanner not working with it and people returning them.
It will talk to the ABS ecu and will have read functions on the serial number but beyond that not much good. Jason |
Thanks, it was working! It seems to have the ability to read both but right now it is not reading? 2010 Range Rover MkIII Autobiography Super Charged (Idris)
I have that with my Nanocom sometimes. just a restart works most off the time for me. Roel
1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
Well went out this morning plugged it in and bam! No issues... Guess my ECUs just wanted a break from speaking.
![]() 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
