Home > Td5 > TD5 De-Cat
Tank
Scotland 2004 Defender 90 Td5 HT Zermatt Silver
TD5 De-Cat
TD5 De-Cat
Well that was fun !
Not really a job to try and do without a decent set of ramps or a fur post lift !
Did the cross member removal method but ended up going to my friendly local National Tyre Depot and the guys let me use the four post lift and gave me a lot of help Smile
All done , if a pain, and sounds good.
Once I fix the MAF it should stop smoking as much because at the moment it does the proper TD5 guff big time Smile Nice black cloud !
That the de-cat done, the big intercooler and just to decide if I go BAS or Alive !
Let the fun begin Smile
Post #472540 14th Nov 2015 8:57pm
K9F
Did mine on the drive no ramps. Crossmember and front propshaft disconnected. Only bain was getting the small emersion heater sized catalytic convertor out. Had to jack the engine to get the extra 3-4mm required on my Puma. If you go through life with your head in the sand....all people will see is an ar5e!!
Post #472582 14th Nov 2015 10:38pm
landy andy
Td5 one is easy. Tdci one is a pain in the bum, but still doable.
Post #472590 14th Nov 2015 11:07pm
Tank
It was easy using the four post list Smile
Post #472591 14th Nov 2015 11:20pm
Tommo
United Kingdom 2006 Defender 90 Td5 Black LE Java Black
I know this may sound like a naïve question but what is the benefits of a de-cat Embarassed
Post #472620 15th Nov 2015 8:14am
Anderzander
I did mine on the floor - only difficulty was a very tight crossmember. Beforehand I was a little bit concerned about the turbo studs being seized - but they came off ok Smile
Post #472630 15th Nov 2015 9:07am
K9F
Not naive......there's loads of information regarding benefits available at the push of a few buttons....
Just a couple of the many available....
http://www.defender2.net/forum/topic15424.html?highlight=spool
http://www.defender2.net/forum/topic7482.html?highlight=spool If you go through life with your head in the sand....all people will see is an ar5e!!
Post #472653 15th Nov 2015 9:45am
Tommo
Thanks K9F...is de-cat legal??
Post #472732 15th Nov 2015 6:03pm
Tank
Definitely makes a difference.
I only have a small LD back box and it sounds great, you hear the turbo whoosh as well !
Definitely runs better and pulls better.
It smoked a bit when I first did it, big black clouds, but that's stopped now Smile
Just the Tune to do now . . . BAS or Alive ????????
Post #472739 15th Nov 2015 6:19pm
K9F
MOT failure unfortunately, for some anyway......
http://www.defender2.net/forum/topic27248.html?highlight=mot+cat If you go through life with your head in the sand....all people will see is an ar5e!!
Post #472747 15th Nov 2015 6:31pm
Tank
Interesting as I know people with TD5's with a de-cat who have no MOT problems, and since 2014 test change ?
Tank
Post #472810 15th Nov 2015 7:59pm
K9F
Depends entirely on the tester and how stringent his visual check is. Some do get away with it! Thumbs Up
......Some don't! Big Cry
http://www.defender2.net/forum/topic28888....fail+decat
You'll find out soon enough! If you go through life with your head in the sand....all people will see is an ar5e!!
Post #472833 15th Nov 2015 9:01pm
Tank
Thanks K9F , harbinger of doom lol !
Post #472845 15th Nov 2015 9:25pm
K9F
Apologies Tank, Bow down
You did ask! Thumbs Up
Just presented what was available and as a fellow 'decatter' was of interest especially as I had got rid of my original one and did a lot of investigation into the subject issue. At least you'll not be in for any 'surprises' MOT time?
http://www.defender2.net/forum/topic26633....+convertor If you go through life with your head in the sand....all people will see is an ar5e!!
Post #472906 15th Nov 2015 10:42pm
Tank
K9F indeed I did and have until next May to enjoy.
The cat pipe is safely stored should I need it Smile
Tank
Post #472912 15th Nov 2015 11:02pm
