Home > Td5 > TD5 De-Cat |
Did mine on the drive no ramps. Crossmember and front propshaft disconnected. Only bain was getting the small emersion heater sized catalytic convertor out. Had to jack the engine to get the extra 3-4mm required on my Puma. If you go through life with your head in the sand....all people will see is an ar5e!!
14th Nov 2015 11:38pm |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5584 |
Td5 one is easy. Tdci one is a pain in the bum, but still doable.
15th Nov 2015 12:07am |
Tank Member Since: 25 Jul 2014 Location: Fife Posts: 431 |
It was easy using the four post list
15th Nov 2015 12:20am |
Tommo Member Since: 19 Dec 2013 Location: Leicestershire Posts: 830 |
I know this may sound like a naïve question but what is the benefits of a de-cat
15th Nov 2015 9:14am |
Anderzander Member Since: 08 Feb 2011 Location: Lancashire Posts: 999 |
I did mine on the floor - only difficulty was a very tight crossmember. Beforehand I was a little bit concerned about the turbo studs being seized - but they came off ok
15th Nov 2015 10:07am |
Not naive......there's loads of information regarding benefits available at the push of a few buttons.... Just a couple of the many available.... http://www.defender2.net/forum/topic15424.html?highlight=spool http://www.defender2.net/forum/topic7482.html?highlight=spool If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
15th Nov 2015 10:45am |
Thanks K9F...is de-cat legal??
15th Nov 2015 7:03pm |
Definitely makes a difference.
I only have a small LD back box and it sounds great, you hear the turbo whoosh as well ! Definitely runs better and pulls better. It smoked a bit when I first did it, big black clouds, but that's stopped now Just the Tune to do now . . . BAS or Alive ???????? |
15th Nov 2015 7:19pm |
MOT failure unfortunately, for some anyway...... http://www.defender2.net/forum/topic27248.html?highlight=mot+cat If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
15th Nov 2015 7:31pm |
Interesting as I know people with TD5's with a de-cat who have no MOT problems, and since 2014 test change ?
Tank |
15th Nov 2015 8:59pm |
Depends entirely on the tester and how stringent his visual check is. Some do get away with it!
......Some don't! http://www.defender2.net/forum/topic28888....fail+decat You'll find out soon enough! If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
15th Nov 2015 10:01pm |
Thanks K9F , harbinger of doom lol !
15th Nov 2015 10:25pm |
Apologies Tank,
You did ask! Just presented what was available and as a fellow 'decatter' was of interest especially as I had got rid of my original one and did a lot of investigation into the subject issue. At least you'll not be in for any 'surprises' MOT time? http://www.defender2.net/forum/topic26633....+convertor If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
15th Nov 2015 11:42pm |
K9F indeed I did and have until next May to enjoy.
The cat pipe is safely stored should I need it Tank |
16th Nov 2015 12:02am |
