![]() | Home > Puma (Tdci) > Wiper non stop intermitnet |
wow,you must be as drunk as me,coz i cant read what you sayin,lol.
50/50 educated guess, parking switch.........lol. Pov.spec,ftw. 2006, 110,TD5. |
If you're as drunk it should have made perfect sense!
![]() Even in the off position? May as well have been written in Vietnamese. ![]() "I'm not as thunk as dreople pink I am!" ![]() ECU delay marked up as D113 on the diagrams 501-16 - Wipers and Washers sheet 3 of 6. If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17602 ![]() ![]() ![]() |
ISTR that the park switch uses the 'fast wipe' brush on the motor for parking, irrespective of wipe speed. My suspicion therefore is that the park switch has failed short circuit across the park terminals.
My only wonder is that you can stop the wipers at all. |
What's ISTR???? Pov.spec,ftw. 2006, 110,TD5.
Sorry, ISTR means (AFAIK) "I seem to recall".
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6641 ![]() ![]() ![]() |
ISTR = I seem to remember.
It's not clear what the fault is, is it working but only on FAST in all modes, and not parking at all even when switched back off? How are you stopping them if that is the case? Does it run non-stop in intermittent mode (stalk down)? ![]() ![]() |
Seriously
,perhaps the op could give a PRoPER ex[planaytion?? Pov.spec,ftw. 2006, 110,TD5. |
Meh,fuk it,buy a Ford, whatever!! Pov.spec,ftw. 2006, 110,TD5.
jackp Member Since: 30 Apr 2015 Location: West Sussex Posts: 31 ![]() ![]() ![]() |
Wipers stop in off position, but Not in the park position. On intimitnet, slow and fast wipe positions on the stalk (connected to the steering column) the wipers operate at the fast speed usually found at the top position of the stalk.
Thinking now it maybe a combination of things all going wrong at the same time. The stalk maybe causing the wiper speed limitations (shorting out or something?) and the park sensor is causing the random stopping positions? |
Change the park switch first, you may be pleasantly surprised.
Gonarezhou Member Since: 08 Mar 2015 Location: White River Posts: 178 ![]() ![]() ![]() |
Change the relay or change the bottle
