Home > Puma (Tdci) > Wiper non stop intermitnet
jackp
United Kingdom 2009 Defender 90 Puma 2.4 PU Stornoway Grey
Hi,
Looked for some answers and couldn't find anything specific for my problem.
The truck has developed a non parking flat out wiper option for all of the settings. Is this likely a relay or a park sensor? I would have thought the relay would stop it completely from moving if faulty and park sensor would still allow the wipers to operate in different speeds just stopping in random locations. Any info would be greatly appreciated.
Post #470959 9th Nov 2015 2:17pm
jimbob7
wow,you must be as drunk as me,coz i cant read what you sayin,lol.
50/50 educated guess, parking switch.........lol. Pov.spec,ftw. 2006, 110,TD5.
Post #470964 9th Nov 2015 2:41pm
K9F
If you're as drunk it should have made perfect sense! Shocked
Even in the off position? May as well have been written in Vietnamese. Laughing
"I'm not as thunk as dreople pink I am!" Bow down
ECU delay marked up as D113 on the diagrams 501-16 - Wipers and Washers sheet 3 of 6. If you go through life with your head in the sand....all people will see is an ar5e!!
Post #470969 9th Nov 2015 2:54pm
ISTR that the park switch uses the 'fast wipe' brush on the motor for parking, irrespective of wipe speed. My suspicion therefore is that the park switch has failed short circuit across the park terminals.
My only wonder is that you can stop the wipers at all.
Post #470988 9th Nov 2015 4:21pm
jimbob7
What's ISTR???? Pov.spec,ftw. 2006, 110,TD5.
Post #470991 9th Nov 2015 4:32pm
Sorry, ISTR means (AFAIK) "I seem to recall".
Post #470999 9th Nov 2015 4:49pm
Martin
Site Admin
ISTR = I seem to remember.
It's not clear what the fault is, is it working but only on FAST in all modes, and not parking at all even when switched back off?
How are you stopping them if that is the case?
Does it run non-stop in intermittent mode (stalk down)?  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #471000 9th Nov 2015 4:49pm
jimbob7
Seriously
,perhaps the op could give a PRoPER ex[planaytion?? Pov.spec,ftw. 2006, 110,TD5.
Post #471003 9th Nov 2015 4:58pm
jimbob7
Meh,fuk it,buy a Ford, whatever!! Pov.spec,ftw. 2006, 110,TD5.
Post #471005 9th Nov 2015 5:01pm
jackp
Wipers stop in off position, but Not in the park position. On intimitnet, slow and fast wipe positions on the stalk (connected to the steering column) the wipers operate at the fast speed usually found at the top position of the stalk.
Thinking now it maybe a combination of things all going wrong at the same time. The stalk maybe causing the wiper speed limitations (shorting out or something?) and the park sensor is causing the random stopping positions?
Post #471496 11th Nov 2015 8:52am
Change the park switch first, you may be pleasantly surprised.
Post #471519 11th Nov 2015 10:19am
Gonarezhou
South Africa 2015 Defender 110 Puma 2.2 SW Alaska White
Change the relay or change the bottle Whistle
Post #621160 2nd May 2017 9:55pm
