![]() | Home > Td5 > TD5 straining |
CDN38 Member Since: 14 Nov 2014 Location: Courtenay, BC Posts: 729 ![]() ![]() ![]() |
First thing to do on any Td5 that has a new owner is to check the ECU harness fro oil migration.
http://www.defender2.net/forum/topic24119.html?highlight=oil+ecu Check the MAF as well... these would be good places to start |
TOP5N Member Since: 03 Nov 2015 Location: Gloucester Posts: 226 ![]() ![]() |
Thanks. The guy i had it off put a new loom in it... Haven't checked the maf yet thouh
Even with the new loom, there could be oil in the harness still working it's way down to the ECU. Unplug the harness at the ECU, and give it a check to see if it's dry.
Thanks. Where can i find the ecu ?
Stue5 Member Since: 06 Jul 2014 Location: Marche Posts: 111 ![]() ![]() ![]() |
Thanks. I'll check it out.
Under the drivers seat.
If you search through various forum posts on here on the topic, you will find lots of photos and information on how to go about it. "search" is your friend.... |
Also check the turbo wastegate actuator, video about four posts in on this link.
http://www.defender2.net/forum/topic18571....urbo+waste Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
Thanks. After reading up on it a bit more i'm also wondering if the cat could be blocked.... That's sort of how it feels when driving.
Tchecked the loom and it looks fine. I have booked in to have a full stainless system and a cat removal, so i'll see if that makes a difference.
