Home > In Car Electronics > webasto
luke101
Belgium
webasto
Hello,
I installed a Webasto thermo C in defender puma 2.4 everything works on one thing.
1wire from the relay K3 goos to the blower the other ??
someone told me this is going to fuse the blower but this is not true.I've tried it
The blower must go when the vehicle ignition is off.
The blower switch is in position 3
Can someone help me.
Luke 101 Bree Belgium sorry for my english.
Post #470416 7th Nov 2015 4:36pm
VeeTee
Netherlands
Hello Luke,
You can download the installation manual here (even in your own language Wink ). Hope this helps. Cheers, Vincent
1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold)
1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold)
1975 Series III 88 V6, Light Green (sadly sold)
1996 Defender 110 CSW 300 Tdi, Epsom Green (sold)
2000 Freelander 1 TD4 3-drs, Silver (sold)
2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold)
MySite
Post #470432 7th Nov 2015 5:27pm
Martin
Site Admin
From relay K3 you should have one RED wire and one BLACK wire which you need to connect?
If that is correct then I have just worked this out for you:
For a Puma you need to cut the ORANGE wire which goes to the motor fan (blower).
The RED from K3 should be connected to the part which comes from the fan fuse.
The BLACK from K3 should be connected to the part which goes to the fan.
You can, however, do this at the fuse box as I think the Puma fan and connector is hidden?
The Fuse is number 45 (30 Amps) under the steering wheel.
Remove the fuse. This "cuts" the circuit to the fan.
You can then use the RED and BLACK from the K3 relay. Add a new fuse holder to the RED wire from relay K3, and push in the 30 Amp fuse you removed above.
Then crimp 4.8mm wide (not 6.3mm) spade terminals to the RED and BLACK wires from relay K3, and fit one into each side of fuse position 45. Make sure the terminals are insulated from each other and do not touch!
You should fit the RED wire with your new fuse holder to the side of the fuse 45 position which connects to the ignition switch, and the BLACK wire to the side which goes to the fan.
You can find this out which is which like this:
With the fuse removed, turn the ignition switch to "I" (radio comes on). Use a multimeter to find the side of the fuse box slot which has 12V. This is the ignition switch side. Turn the ignition switch off, and fit the RED wire here. Fit the BLACK wire on the other side.
You now have a fan which is under control of the TT-C and the K3 relay, as well as working normally. And no cutting of the car loom required Smile  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #470494 7th Nov 2015 8:42pm
Martin
Site Admin
PS: sorry it is not in Flemish Embarassed  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #470495 7th Nov 2015 8:46pm
Martin
Site Admin
If you have feedback on what I worked out for you above please let me know - did it work or not?  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #471256 10th Nov 2015 11:14am
cobs
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Cairns Blue
Martin/luke - the following is from a pdf (Part 5 - Completing the Installation) in My Gallery. I cut the orange wire on the fan loom as per the section below - which I think is the same as your instructions Martin:
Connect the wiring loom to the vehicle fan.
a. Locate the grey connector with a brown/red
wire and an orange wire that is connected to
the fan motor (passenger side bulkhead) –
cut the orange wire.
b. To remove the grey connector locate the
square hole in the heater housing
underneath the connector (i.e. where the grey connector goes in), Push the grey
connector fully home, insert flat bladed screwdriver into slot and jiggle around,
curse and swear for two minutes until grey connector magically pops out and you
wonder what all the fuss was about!
c. Connect the black wire from the Webasto loom to the orange wire at the grey plug
end i.e. black going into the fan. (I’ll explain why in a minute)
d. Connect the red wire from the Webasto loom to the other orange wire, i.e. going
back into the vehicle’s wiring loom.
e. Use proper connectors and heat shrink tubing or similar to seal.
f. Replace the grey connector
g. How does it work? The red and black wires are connected together at the relay (the
one you fixed to the bulkhead with the rivnut) When the Webasto is turned off, i.e.
under normal vehicle operation, these red and black wires simply form a loop which
connects the two cut ends of the orange wire so the fan can operate normally.
When the Webasto is switched on however the Webasto needs to provide power to
the fan and switch it on. It does this by providing power to the relay which
disconnects the red wire and provides 12V to the black wire. This is why you need
to connect the black wire to the grey connector end to make it work and not the red
(which would be more logical to my mind – but then I’m not an electrician). I’ve
read somewhere that the fan gets switched on when the coolant temperature is
above 30C however mine seems to come on as soon as the Webasto is switched on.
Post #471585 11th Nov 2015 1:45pm
Martin
Site Admin
Glad it agrees with me on the installation wiring Thumbs Up  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #471659 11th Nov 2015 4:47pm
