![]() | Home > In Car Electronics > TD4 Fusebox terminals |
Try these:
http://uk.rs-online.com/web/c/?sra=oss&...+terminals http://www.dingocroft.co.uk/cgi-bin/ss0000...TION=Go%21 http://www.vehicle-wiring-products.eu/page.php/error404 If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
PaulMc Member Since: 17 Jan 2009 Location: Kent Posts: 504 ![]() ![]() ![]() |
STC4034, STC4035, and STC4036 look like this - ![]() These are for the Blade fuse box PRC4826 - ![]() Which was fitted to late 200Tdi and 300Tdi Defenders. For terminals to fit the Grote and Hartmann (Lear) fuse carriers fitted to Defenders from TD5 (1999) onwards - ![]() Click image to enlarge Have a look here - http://www.defender2.net/forum/post96207.html#96207 and here - http://www.defender2.net/forum/post145671.html#145671 . Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() 1989 Arles Blue 2.5TD 110 Hardtop 1999 Epsom Green Discovery II 4.0 V8i 'XS' |
Cetane Member Since: 27 Nov 2012 Location: Lancashire Posts: 171 ![]() ![]() ![]() |
Just to be clear they fit and lock in position on the Puma fusebox?
If so, I'll grab some off you. Finding any is a nightmare! Cetane |
Yes, they fit and lock into the Puma and TD5 fuse carriers.
They are made by the same manufacturer (Grote & Hartmann) They're slighty different in detail to the factory terminals - however, the important dimensions are the same as the factory terminals. . Paul. 1989 Arles Blue 2.5TD 110 Hardtop 1999 Epsom Green Discovery II 4.0 V8i 'XS' |
Great
You have a PM. |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17598 ![]() ![]() ![]() |
Got to ask, what's a "TD4" Defender? I thought that only the Freelander used a TD4 engine? Perhaps you mean TDCi?
