Home > In Car Electronics > TD4 Fusebox terminals
Cetane
United Kingdom 2010 Defender 110 Puma 2.4 HT Galway Green
Does anyone know where I can source some female terminals to fit the blades in the fusebox under the steering wheel in a 2010 Defender?
I found these part No's at the local dealer, but they are to suit Td5 spec fuseboxes in front of the gear stick.
STC4034
STC4035
STC4036
Are they interchangeable with the newer box?
I've also tried the guys at Mobilecentre, but to no avail.
Cetane
Post #469404 4th Nov 2015 4:58pm
K9F
Try these:
http://uk.rs-online.com/web/c/?sra=oss&...+terminals
http://www.dingocroft.co.uk/cgi-bin/ss0000...TION=Go%21
http://www.vehicle-wiring-products.eu/page.php/error404 If you go through life with your head in the sand....all people will see is an ar5e!!
Post #469408 4th Nov 2015 5:06pm
PaulMc
Re: TD4 Fusebox terminals
STC4034
STC4035
STC4036
Cetane
STC4034, STC4035, and STC4036 look like this -
These are for the Blade fuse box PRC4826 -
Which was fitted to late 200Tdi and 300Tdi Defenders.
For terminals to fit the Grote and Hartmann (Lear) fuse carriers fitted to Defenders from TD5 (1999) onwards -
Have a look here - http://www.defender2.net/forum/post96207.html#96207
and here - http://www.defender2.net/forum/post145671.html#145671
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Paul.
Post #469455 4th Nov 2015 6:14pm
Cetane
Just to be clear they fit and lock in position on the Puma fusebox?
If so, I'll grab some off you. Finding any is a nightmare!
Cetane
Post #469462 4th Nov 2015 6:30pm
PaulMc
Yes, they fit and lock into the Puma and TD5 fuse carriers.
They are made by the same manufacturer (Grote & Hartmann)
They're slighty different in detail to the factory terminals - however, the important dimensions are the same as the factory terminals.
. Paul.
Post #469465 4th Nov 2015 6:39pm
Cetane
Great
You have a PM.
Post #469470 4th Nov 2015 6:46pm
Got to ask, what's a "TD4" Defender? I thought that only the Freelander used a TD4 engine? Perhaps you mean TDCi? Rolling with laughter
Post #469493 4th Nov 2015 7:18pm
