Home > Puma (Tdci) > Defender PUMA = unstopable. Dune driving suggestion.
Page 2 of 4 <1234>
Sonic3d
United Kingdom 2010 Defender 110 Puma 2.4 XS DCPU Stornoway Grey
BigMike wrote:
i dont agree about tyre pressures. you drop your pressure and you run a serious risk of popping the bead(s). I;ve never had any problem in sand keeping the pressures at normal. Put it this way, I'd rather get stuck than have to put a tyre back on.
You would soon change your views when stuck in a sea of sand Thumbs Up
Post #46842 30th Nov 2010 9:35pm
BigMike
I'm happy doing it the way I was taught and the reasons why. normal pressures, high revs, low box works fine Thumbs Up
Post #46846 30th Nov 2010 9:47pm
Sonic3d
Have you ever driven in proper sand? ie Morocco / Tunisia
Post #46849 30th Nov 2010 9:50pm
BigMike
morocco, saudi arabia, oman, yemen, jordan, iraq, syria, so yes, "proper sand".
Post #46856 30th Nov 2010 10:10pm
Sonic3d
I just find it hard to understand your views against lower tyre pressures when it's well proved that it works Rolling Eyes The larger you can make your foot print the better the vehicle will travel Thumbs Up High tyre pressures make your foot print smaller.
Post #46858 30th Nov 2010 10:16pm
BigMike
There's no appreciable difference. its one of those things that found its way in to offroad driving myth. You get a marginally longer footprint, yes, but its very marginal. that's far outweighed by the risk of popping a bead or multiple beads all at once. The guys I work with who train several forces who operate in the desert are unanimous in this, "dont lower your pressures". each to their own, whatever people want to do is cool, i just wont be lowering pressures, and so far, and after thousands of desert miles, many of which in soft sand I've never had an issue. Give it a go.
a far bigger issue in sand is the weight of the vehicle. a fully laden expedition vehicle will definitely find it tougher going.
Post #46865 30th Nov 2010 11:32pm
Sonic3d
Wouldn't call it a myth as it does work Thumbs Up I ran Staun alloys with the bead locks and dropped my pressures down to 10psi and it made a huge difference. As you say weight is a problem Thumbs Up
Post #46867 30th Nov 2010 11:38pm
Naks
My man, you are sorely mistaken. Weight is a factor, but dropping your tyre pressure is a must when going offroad, esp in sand.
The rule some people use in SA is as follows:
When you go offroad, halve the current tyre pressure. This works brilliantly on gravel.
For sand, drop to 1.0 bar, and if need be, 0.8 for very soft sand.
Post #46874 1st Dec 2010 6:31am
roel
I know the Dutch army isn't lowering tyre pressure but we had a lot off laughs when they were digging there Merc out when we were driving around them at around 1 bar. Laughing
The army does it because the drivers forget that low tyre pressures on the road are dangerous.
That 10 times hitting the brake to stop TC working, is that not cancelled when you go over 7 or 10 km/hr like with the Td5's? Roel
2003 90 Td5 (2009-now)
Post #46890 1st Dec 2010 9:08am
Naks
roel wrote:
I know the Dutch army isn't lowering tyre pressure but we had a lot off laughs when they were digging there Merc out when we were driving around them at around 1 bar. The army does it because the drivers forget that low tyre pressures on the road are dangerous.
Rolling with laughter
Post #46891 1st Dec 2010 9:09am
BigMike
the army (various special forces included) doesnt do it because can you imagine a team of guys in a truck racing away from an engagement and being chased? "hold on a minute lads, we need to stop and lower the tyre pressures before we get into the sand" Laughing
as I said, each to their own, but I've never had a problem and am happy doing it this way.
Post #46894 1st Dec 2010 9:36am
DefenderOfTheEarth
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Tonga Green
LOL! If in doubt, use the Forces (especially Special Forces) to prove a point...
They aren't always right and have to make do with what they are supplied with. Not always the best kit for the job.
I'd sooner take advice from a reputable exploration team/company than the Forces. Defender 110XS SW gone... now VW California 180 4 Motion.
Post #46900 1st Dec 2010 10:32am
BigMike
And again, each to their own. It works fine for me, I'm not sure why thats something to find amusing
Post #46902 1st Dec 2010 10:48am
Andrea
but removing the ABS fuse, and she sailed up no problem,,
How does 1 remove the ABS fuse, is it under the seat or in the engine?
Question
Post #46914 1st Dec 2010 12:23pm
Naks
Re: but removing the ABS fuse, and she sailed up no problem,
under the steering column, two plastic screws that you can undo with a R2 coin.
Post #46921 1st Dec 2010 12:51pm
Page 2 of 4 <1234>
